Garmin heart rate monitor reading too high
I find my garmin HRM reads between 160-220 a good part of the time. I tried using water for the contacts against my skin and swapping out the battery.
Does a high reading suggest a contact problem or a low battery or something else? Maybe the battery I put in was bad?
thanks,
Aluminum Man
Re: Garmin heart rate monitor reading too high [Aluminum Man] [ In reply to ]
Are you getting the readings while running? if so, the culprit is likely static electricity building up between your shirt and the transmiter (especially if it is the soft strap).
First, try washing the strap. That often helps.
If it doesn't, try using Static Guard before you work out. Definitely solves the problem, but is also kind of a BS work around for a poor design. IMO, of course!
Chicago Cubs - 2016 WORLD SERIES Champions!!!!
"If ever the time should come, when vain and aspiring men shall possess the highest seats in government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
I found cleaning the contacts with contact cleaner worked best for me. If you could see the contacts under a microscope you would be suprised how dirty they can be when they look clean to the naked eye.
jaretj
same problem with me for a strap only 5 runs old. I have heard that the problem goes away with the polar wearlink strap, but have yet to try that.
Gary Geiger
http://www.geigerphoto.com Professional photographer
TEAM KiWAMi NORTH AMERICA http://www.kiwamitri.com, Rudy Project http://www.rudyprojectusa.com, GU https://guenergy.com/shop/ ; Salming World Ambassador; https://www.shopsalming.com
Re: Garmin heart rate monitor reading too high [ggeiger] [ In reply to ]
If I need to go with this solution, are you suggesting just getting this polar strap or a whole new HRM from Polar?
thanks,
Aluminum Man
I have the older plastic strap HR monitor and I usually get erratic readings in the first 10 minutes or so especially if I run outside where it is drier then indoors. When I'm running, I press my hand against my chest (holding the shirt next to the HR monitor) for a couple minutes and that is usually long enough for some moisture from sweat to take care of any static electricity problem. I sometimes wonder if people passing by think I'm having a heart attack, but the rescue squad has never tracked me down so nobodies been too concerned yet.
You just need to get the Wearlink + strap. The Garmin transmitter will then press fit onto the strap. This is what I have done and my HR readings are much improved.
If you're using the newer softer strap it's because of static build up. There are a few ways to avoid it, you can soak the entire strap with water, or you can rub a dryer sheet on the strap/your shirt before you start running. I was having the same issue on the run and on the bike, though now these techniques seem to help.
http://www.facebook.com/ReconFoundationTeam
http://www.facebook.com/MarineReconFoundation
http://www.reconfoundation.org
I had the same problems. I went back to the older plastic strap and tightened the strap a little more. I think the elastic in the Garmin straps wears out easier and doesn't hold the monitor close to the skin after some time. About every month I tighten it about a 1/2 inch.
Re: Garmin heart rate monitor reading too high [TriMarine] [ In reply to ]
I've been soaking the entire strap (not just the contact points) and it's mostly gone away. This was happening in both running and riding early on. It was going away later, but that was because I had been sweating enough to soak it. Wash the strap off too. Clean of the metal connectors between the strap and the battery section.
I had same issue. Got the Polar strap (just the strap without the transmitter). I snap my Garmin transmitter (from the soft strap) into the Polar strap.
I bought the strap on Amazon and got the suggestion for some conductivity gel, so I got that too. Since using the Polar strap (with Garmin transmitter) and the gel I have had zero problems.
Do it. Now!
Civilize the mind, but make savage the body.
- Chinese proverb
Re: Garmin heart rate monitor reading too high [brigby1] [ In reply to ]
I had the same problem and called garmin and they sent me out a new strap and everything is working just fine. They said they had a problem with the old strap.
Re: Garmin heart rate monitor reading too high [Burnt Toast] [ In reply to ]
I occasionally get exactly this problem. Starts high and erratic and settles down after five or ten minutes (presumambly when I have built up a sweat?). A smear of electrode gel on the contacts seems to eliminate it (I haven't tried the "press hands to chest" method!)
http://rogersroadrash.blogspot.com/
Re: Garmin heart rate monitor reading too high [Rolly Jogger] [ In reply to ]
I have the problem in August in Florida so I know static isn't my problem. It is such a pain I no longer use the HRM. I never had a problem with my Polar.
You should not experience static issues this time of year,especially if you moisten the strap sensors. I can only discuss Polar, and any HR issue is usually a Wear Link that needs washing,hand wash 1-2x a week in cool to warm water and hang dry.
Re: Garmin heart rate monitor reading too high [Wayne@PolarUSA] [ In reply to ]
All of my static problems happen this time of year. Very dry, cool air. Just saying.
- Chinese proverb
Re: Garmin heart rate monitor reading too high [Duffy] [ In reply to ]
What are your weather conditions now and where do you live? I often here about "the dry heat" so maybe in AZ or NV it could be 20% humidity. Moisten the fabric or plastic transmitters and maybe use some water and moisten the shirt/jersey in contact with the the transmitter. We do not use static guard at Polar, we might have 30 years of hr technology where others have more gps history.
Santa Barbara, CA.
Cool dry fall/winter. Except when it's raining.
If you look up at my previous post you'll see that I haven't any issues since I dumped the Garmin strap and got a Polar strap (with the Garmin transmitter snapped on). Also the conductivity gel helps, I suppose.
It was never a problem in the summer because it's always overcast here or I'm not wearing a shirt.
- Chinese proverb
Minnesota, the fall and winter are the worst times for static electricity.
This happened to me today too with my Garmin 305- first 10-15 min of run HR spiked to 216. I'm in Colorado and it was 18 degrees when I started my run this am. I've only had the Garmin a year and don't usually use the HR portion, just like to know my mileage. On my polar, I've never seen my HR over 175. For the rest of the run everything was then normal. thanks for the tips and suggestions for avoiding in the future
Re: Garmin heart rate monitor reading too high [KTMay] [ In reply to ]
I had the same problem when it was dry and cold with the basic Garmin HRS and Monitor. I bought a Garmin Premium Heart Rate Strap and Monitor and use a little conductivity gel and that has solved the problem.
Here is a link to the Polar strap that many people say is better than the Garmin strap http://www.amazon.com/...ativeASIN=B000OL06A4
The basic Garmin monitor will not work with the Polar strap but the Premium Garmin Monitor will.
Re: Garmin heart rate monitor reading too high [ccassidy] [ In reply to ]
Here ia a link to the conductivity gel
http://www.amazon.com/...A8RQ/ref=pd_sim_sg_2
