Estimating drag without a power meter
Here are speed data from two coastdowns I did yesterday afternoon. The speeds are in km/h at one second intervals. As I said, these were coast downs so power, of course, was zero. I forgot to weigh myself and the bike when I got home so I'm guessing the all-everything mass to be around 86 kg. I didn't measure air density but I'm thinking it must be around 1.17 kg/m^3. And the total drop from entry to exit of the test section was about 5 meters. Besides not measuring my mass or the air density, there was a tiny amount of wind in my face during the test runs -- but let's ignore all those problems and simply assume wind was zero and everything was exactly as noted above.
Here's the challenge: based on these data, can you estimate my CdA and Crr? Show your work. This was on my commuter bike and I was wearing street clothes so don't give me crap about my drag numbers.
Run 1:
15.2 15.8 16.3 16.9 16.9 17.4 17.7 18.1 18.5 18.9 18.6 17.9 17.9 18.6 19.7 20.0 20.9 21.6 22.5 22.5 23.4 23.7 23.5 24.3 25.1 25.7 26.0 25.6 25.3 24.6 24.2 23.9 23.5 23.1 22.9 22.6 22.3 22.3 22.0 21.9 21.7 21.8 21.4 20.7 20.9
Run 2:
26.6 26.6 26.6 26.5 26.6 26.8 26.1 25.4 25.6 26.3 26.8 27.3 27.9 28.4 29.1 28.7 29.6 29.8 30.6 30.3 29.7 29.2 28.7 28.3 27.4 27.2 26.7 26.1 25.8 25.5 25.3 25.0 24.5 24.2 23.9
Re: Estimating drag without a power meter [RChung] [ In reply to ]
RChung wrote:
Show your work.
Feels like high school all over again :)
I'll bite. I could be way off base here though.
F = ma = (1/2)(rho)(CdA)(v^2)
Acceleration can be found by the slopes between each data point. A plot will estimate CdA (the only unknown) with a line of best fit. I'll crunch these in Excel when I get home.
Re: Estimating drag without a power meter [Jamaican] [ In reply to ]
Close. How will you find Crr?
'Integrate' using the trapezoids to obtain total displacement.
Use the stated 5m drop with displacement & we have a slope (theta).
F = ma = Crr*N, where N = mg*cos(theta)
A plot with line of best fit will estimate Crr. Am I close?
Very good. Now make the estimates.
Ok Final Solution. I think I had it wrong before. I'll run these in excel in a few hours & put up the results.
F(rr) + F(CdA) = ma
Crr*N + (1/2)*(rho)*(CdA)*(v^2) = ma -------------------------------------------------- (1)
Acceleration a is found using the slope b/n velocity data points. The v used in (1) is the average velocity between points n & n+1.
Find the area underneath the velocity points (trapezoids) for total displacement. Using drop h = 5m, we find average slope theta
N = mg*cos(theta)
In equation (1), the only unknowns are Crr & CdA. Dividing throughout by N, it takes the form "y = mx + b", & we can estimate Crr (intercept) & CdA (slope) from the line of best fit.
Let me try: CdA=0.37 and Crr=0.0066
Ale Martinez
www.amtriathlon.com
Re: Estimating drag without a power meter [Ale Martinez] [ In reply to ]
That's what I got.
Anyway, now that so many people have bike computers that can record speed (like the Garmin units) I thought it would be good to point out that it's possible to estimate drag using one even if you don't have a power meter.
What was the difference between Run1 and 2? The ave speed was higher for 2
Styrrell
Re: Estimating drag without a power meter [styrrell] [ In reply to ]
I purposefully started the second coast down run at a higher initial speed.
I got that Crr but my CdA is off .....
May be because your force balance equation (1) above lacks the gravitational term
Ale Martinez
www.amtriathlon.com
RChung wrote:
That's what I got.
Yes, is quite interesting if you have the rigth venue!
BTW, did you use VE for the solution ? I have used an energy conservation approach.
Ale Martinez
www.amtriathlon.com
This was just a normal street between my house and office where there's not much traffic. In fact, I noticed at lunch time that it appeared to be almost calm so I did a couple of coastdowns then went back to the office (as I said, on my commute bike and wearing street clothes). When I ran the numbers I was shocked that I was so far off from what I expected. Either the Crr or CdA was way off. So I checked my tires and realized that both my front and rear tires were way under-inflated. I pumped up the tires and tried again on the way home. These were the data from the afterwork runs, though by then there was a tiny bit of wind. I was using my frame pump so I don't know what the tire pressure was before or after.
I do both. I used the closed-form approach to solve it but I used VE to check the answer.
I should perhaps add that starting the second coast down at a different speed than the first is what makes both CdA and Crr estimable.
That's one of the reasons why I recommend that when you're doing "regular" VE runs that you do them at different speeds.
Can you post a spreadsheet that calculates this?
Re: Estimating drag without a power meter [CptanPanic] [ In reply to ]
Ugh. I'm horrendous at doing spreadsheets.
I'll try to pull together something understandable later this afternoon.
Since your speed dropped after you got down the hill did you just use the data from going down the hill to figure out the acceleration or did you do it all by parts?
Re: Estimating drag without a power meter [jaretj] [ In reply to ]
Actually, the entire test section was downhill -- however, the slope wasn't constant. The end of the course was pretty shallow. The slope varied so the speeds and accelerations varied. In addition, I started the coast down runs at different speeds. Those speeds and accelerations (and decelerations) help in nailing down the CdA and Crr.
I've wrote this little one, you can load up to 10 coast down tests (in Run1, Run2, ... columns and n=number of tests), Mass (M), Air density (rho) and descent (h in m) and it gives you estimates of CdA and Crr via linear regression and a graph with virtual elevation for each run:
Ale Martinez
www.amtriathlon.com
So how did you collect all the data points? Memorization?
"We don't inherit the Earth from our ancestors, we borrow it from our children." --Chief Seattle
You used regression? What was the model you were estimating.
CptanPanic: Sorry, I told you I'm terrible at spreadsheets. I worked on it a little but then got distracted by something else and didn't get back to it. Ale's is nicer anyway.
osugasman: I recorded the speed data with my power meter but if you have anything like a Garmin (which many people do) you can use that to record the data.
I love you guys!
I can't wait to try this!
Running is a gift.
This Month's "Sport Biomechanics" has a rundown of ways to estimate drag.
The coast down is in there as well as a couple I hadn't thought of.
One is to take a picture of the rider from the front and in the frame also have something that is a reference area, maybe a 0.5 meter by 0.5 meter square. Then cut out the reference area and the parts of the rider and then weigh them to compare. My analytical chemistry professor told me years ago this is how he did integration on chemical equipment years ago.
Of course we also have a a number of ways to do this electronically these days as well using gim p or photoshop or whatnot.
