My computer was fading in and out. It is 1 yer old. I took it of the "bar connector" and there was a lot of guck from sweat on the contacts. I cleaned them and it seems to have helped. Is this it? Anythign else I can do? I do not want it to go out at my race this weekend. Thansk
Re: Computer going in and out. [Freedie]
probably the contacts if they are gunked. In addition to just wiping them off, you can give them a swipe with real fine sandpaper too.
did you replace the battery? sounds dumb but sometimes it's that simple.
Clean the contacts with a Q-tip dipped in alcohol, and replace the battery. That ought to do it for you.
<If you're gonna be dumb, you gotta be tough>
Get Fitter!
Proud member of the Smartasscrew, MONSTER CLUB
Get your FIX today?
Get Fitter!
Get your FIX today?
Also check the speed and cadence sensor alignment (if so equipped). Ocassionally when I remove the front wheel it bumps the speed sensor and shifts it slightly out of position so it's too far from the magnet to get a consistent reading. One of your sensors or magnets may have slipped a little.
