What do you do with your hair?
I just got a new aero helmet and was wondering what is the right way to use it? Are you supposed to put your hair inside the helmet?
Re: What do you do with your hair? [marcia] [ In reply to ]
I wear my hair in a low ponytail w/ the aero helmet. Works fine.
Re: What do you do with your hair? [Elsa] [ In reply to ]
When my hair was too short for a low ponytail I did low pigtails. I don't think it was very aero. I couldn't fit my hair in under the helmet though...
Mine is long enough to french braid, and the end of the braid does fall outside the helmet but flat down my back. I suppose I could tuck the end of my braid up if I wanted it under the 'tail' of the helmet, but I don't know that it would make that much of a difference.
Re: What do you do with your hair? [kmeris] [ In reply to ]
Low pony. Was a long braid when longer, and a french braid when same length as now, but now is much more layered so won't stay in a french braid.
while we are on the subject- what does everyone do with their hair on the swim? somehow the ponytial with band doesn't fit well under a swim cap, so I just twist it up and put the band on my wrist. After the swim goggles and cap off, band onto hair. Other suggestions welcome.
Re: What do you do with your hair? [triFP] [ In reply to ]
I've got a single long braid. I roll it up and put an elastic around the middle of the roll. Tuck it under my swim cap that way, and then the tail of my aero helmet covers it on the bike. The roll also keeps the braid from sticking to my sweaty arms on the run.
No coasting in running and no crying in baseball
I put my hair in 2 braids.
Low pony tail, now that it is longer. Low enough to fit under helmet, high enough to fit through hat and under swim cap.
mmm-mmm-Momo Charms
Handmade beverage charms, jewelry, and miscellanea
http://momocharms.wordpress.com
Re: What do you do with your hair? [maija] [ In reply to ]
^^ this. pigtail braids don't interfere with centre-mounted helmet adjusters, but it still keeps the hair the hell out of my way.
cheers!
-mistress k
__________________________________________________________
ill advised racing inc.
On the swim, I don't really have a problem just low pony tail and stick it under the cap. If I put the pony tail to high i do have a harder time with the cap
