Low RBC/WBC counts...cause for concern?
I just had my annual physical and it was discovered that I had low RBC/WBC counts...am under the assumption that this is related to an immunodeficiency?? I haven't gotten sick that often over the past years but did have a severe asthma attack which lead me to be pulled off the bike course at mile 100 at Kona this year. My oxygen saturation dropped pretty low and I was hypertensive when taken off the course...could have this affected my bloodwork? Anyways, I was wondering if this is something I should be concerned about or need further check up on? Any doc's able to help me with this?
Thanks,
Kim Brown, MS, RD
Sports Nutritionist
http://www.kbnutrition.com
Kim Mueller, MS, RD
Sports Nutritionist
Re: Low RBC/WBC counts...cause for concern? [KimBrown] [ In reply to ]
How about some actual numbers.
Re: Low RBC/WBC counts...cause for concern? [Sojourner] [ In reply to ]
WBC 3.7 K/ul RBC 4.1 M/ul Thanks!
Kim Mueller, MS, RD
Sports Nutritionist
Kim, I know that having low RBC would be a concern, what is your Hgb? As for WBC if that is low not sure, but what does your doctor say? I have a rare bleeding disorder, so when my RBC is low my Hgb is usually low as well. I would talk to your doctor and do some research on your own. Doing research on your own is always good. Did you get a copy of your labs?
Re: Low RBC/WBC counts...cause for concern? [runnergirl] [ In reply to ]
My iron levels (hemoglobin/hematocrit) are normal. I haven't found any thing definite in my research of the issue. A low WBC count is indicative of a depressed immunity although I haven't been sick for a long time. This is all fascinating to me since I am interested in physiology...just thought I'd try to get some feedback from any athletic docs on this forum. Healthy trails, Kim Brown, MS, RD Sports Nutritionist http://www.kbnutrition.com
Kim Mueller, MS, RD
Sports Nutritionist
Kim: need more info, sorry.
Your hematocrit (% of red blood cells in serum) is usally about 3 times your hemoglobin level. If you are anemic, there are a lot of different types and reasons why. Need to know your RBC morphology - my first guess would be iron deficiency anemia (based on most common). However, most endurance women athletes (if you were at Kona, that certianly counts) have little to no menstration anymore.
A single lab test with a low white blood cell count means very little in the abscence of other symptoms/lab findings. Repeat the bloodwork in a few weeks. Also, there should have been a breakdown here as well (%neutrophils, etc.)
Fatigue is biochemical, not biomechanical.
- Andrew Coggan, PhD
I'm not a doctor, but I believe your WBC is only to be elevated when you ARE sick. Isn't that what they are for, to fight (actually eat I believe) off things that aren't supposed to be in you? Your iron levels and your hematocrit and hemoglobin levels are not the same. Did you get any paperwork for you to look at? If your hematocrit is around the 37% mark it's kind of low for a female, as with readings under 13 for your hemoglobin. Any hard numbers for those two indicators?
Here is the full blood workup:
WBC: 3.7 k/ul
LYM 1.3, 34%L
MID 0.3, 7.4%M
GRAN 2.2, 58.6%G
RBC 4.1 M/ul
HGB 13.2 g/dl
HCT 38.7%
MCV 92.6 fL
MCH 31.6 pg
MCHC 34.1 g/dL
RDW 12.2%
PLT 263 k/ul
MPV 8.8 fL
Another flag was BUN/CREAT ratio being elevated (31.4) and creatinine being low (0.5 mg/DL)
Lower-than-normal levels of creatinine may indicate:
  • Muscular dystrophy (late stage)
  • Myasthenia gravis
Elevated levels of BUN/CREAT ratio may indicate
Considered together, the BUN, blood creatinine and their ratio give very good evidence of the filtering function of the kidneys and also, a measure of the degree of bodily hydration. The ratio of BUN: creatinine is normally 10:1. With dehydration, the ratio can increase to 20:1 or even higher. This makes sense because I came from a very intense workout that morning and most likely was a dehydrated...spent the rest of that day rehydrating.
Kim Brown, MS, RD
Sports Nutritionist
Kim Mueller, MS, RD
Sports Nutritionist
I'll defer to rroof, but it seems like your 'crit and hemoglobin are within the normal range for a female.
Didn't you have a physician give the physical and interpret the labs for you? What did he/she say?
_______________________________________________
I would be a little worried if my nutricionist couldn't either read bloodwork that or didn't have handy a source to look it up. But that's just me.
"Yeah, no one likes a smartass, but we all like stars" - Thom Yorke
smartasscoach.tri-oeiras.com
Re: Low RBC/WBC counts...cause for concern? [smartasscoach] [ In reply to ]
Why would a nutritionist need to know how to read a blood test besides chloesterol (sp?)?
Unless nutrition affect RBC/WBCs...maybe the pros are eating something to raise their hemocrit levels??
TheBikeRacer.com
Smartasscoach...
I do have books/access to information as everyone else does but thought I may gather some better input from specialists, doctors who may give me something a little more valuable than textbook knowledge. I am always looking to expand and by outreaching to other professionals in forums like Slowtwitch, I find myself learning more valuable information than what can be found in books.
I guess my outreach for help is very much like a coaches/doctors asking me for my expert knowledge on nutrition even though I am sure they have at least a textbook knowledge on the subject.
Healthy regards,
Kim Brown, MS, RD
Sports Nutritionist
www.kbnutrition.com
www.kbnutrition.com
Kim Mueller, MS, RD
Sports Nutritionist
Re: Low RBC/WBC counts...cause for concern? [mwbyrd] [ In reply to ]
Mine does... I guess I'm spoiled. But like I said, it's a personal opinion.
FWIW your RBC count is normal,
Your WBC is lower but you don't seem to have a specific population affected (lymph/PMN/mono percentages are all normal).It's pretty nonsepcific - did you just have the flu?
Don't trust your nutritionist to interpret your blood chemistry. I'm suprised s/he would even attempt to do that. There's many things that can be going on with your blood chem that a nutritionist wouldn't know about or pick up on.
Your creatinine is also related to your muscle mass (as well as your kidney function.) More muscle, more creatinine. The BUN is related to protein intake as well as kidney function. The elevated BUN/creatinine may be related to relative dehydration, as well. If you consume a lot of protein and have a small muscle mass, this could effect the relative ratios.
Your total granulocyte count is normal, so the lowish WBC count probably is OK. Your red cells are borderline large, so your RBC count will be lower for the same Hemoglobin level. Large RBC may be related to reduced B12 absorption or decreased folate intake. Hemolysis can give you largish RBC'c as well. A reticulocyte count, folate and B12 levels might be instructive. But, most likely these are normal variants. I'm not an adult doc, so you might want to confirm this with an internist or hematologist.
_________________
Dick
Take everything I say with a grain of salt. I know nothing.
Re: Low RBC/WBC counts...cause for concern? [docfuel] [ In reply to ]
I'm not sure you can call an MCV of 92 increased when the average normal values are ~80-100
edit: also, sorry for the nitpicky nature of this, but her total neutrophil count is low too, in proportion to the other WBC subsets.
Re: Low RBC/WBC counts...cause for concern? [jhc] [ In reply to ]
Don't think I have the flu although it is funny that you mention that cuz when I went to go see the doc, I hadn't been able to keep anything in my system and was running a slight fever...I related to something new I ate but suppose I could have had a bought of the flu. And the combination of my intese workout I did that morning and not being able to hold anything in my system explains the dehydration and BUN/CREAT abnormality. Smartasscoach...hearing such input from experts, people who draw blood and look at blood chemistry values every day, is why I am on this forum cuz the info is far more valuable than regurgitated information from a textbook.
Healthy regards,
Kim Brown, MS, RD
Sports Nutritionist
www.kbnutrition.com
Kim Mueller, MS, RD
Sports Nutritionist
>>...hearing such input from experts, people who draw blood and look at blood chemistry values every day, is why I am on this forum<<
Interesting, considering about 95% of the people on this forum post anonymously so do you really know if they are who/what they say they are???
clm
clm
Nashville, TN
https://twitter.com/ironclm | http://ironclm.typepad.com
Re: Low RBC/WBC counts...cause for concern? [ironclm] [ In reply to ]
Yes, you are correct in that you always have to be careful as to who you take information from. When reading responses from others, I do my own homework too to make sure the information meshes with what I know to be true. I also seek out personal help from professionals I network with in the area.
Kim Mueller, MS, RD
Sports Nutritionist
The lymphocyte counts are relatively less important. Lots of people have lowish WBC's, but ia total granulocyte count to 2000k is fine. The normal tables I use list adult nomrals from 80-92, this does vary from lab to lab. MCV is a ratio of RBC count to hematocrit, so for the same hematocrit the RBC numbers will vary by cell size.
_________________
Dick
I'm curious as to what your actual doc said.
(PS - I'm not an expert, I'm a med student)
There seems to be a lot of variation in normal values, I've now seen "normal" values for total neutrophils as 1800-(I forget the upper value) [a hematology book], 2500-7500 [some page on the internet], and 3000-5800 [Conn's Current Thereapy] And MCV ranges 80-100, 70-100, 80-96. Probably the source of confusion.
Interesting that you said that the lymphs were less important. Maybe that's true when you think about opportunistic infections, but if I had a patient with low WBC, normal total neutrophils, and pretty low lymphs, I'd be concerned about the underlying cause of that.
3.7 WBC is not a problem. I'm at 2.7 and the hemotolgist told me that the range isn't exact. He said 2.7 does not concern him. Different ethnic groups fall in different ranges.
Olen
