I am at a stand still with my tri build and hope that ST can help with the last details. I own the Simkin's Egg Brakes which I feel are about some of the best aero brakes going BUT have been thinking about the T726R mounted on both the front and back and feel that this would be a better set up for the bike since it appears to be more aero with the cables running down the center of the head tube and directly behind the seat tube.
The only issue with mounting the T726R will be custom making the mounts for both the back and front to run the cables the correct way but not that hard. Also will have to get a longer brake bolt for the front.
So I am approaching ST to get your thoughts on both brakes and what might be the pros and cons of each set up.
Thoughts?
Thoughts?
