3SIXTY5cycling.com
Re: Retro TT stuff [jeremyb]
3SIXTY5cycling.com
Re: Retro TT stuff [hillier99]
3SIXTY5cycling.com
Apparently, the bulge kept your feet/crank out of the wind...
Brad
3SIXTY5cycling.com
3SIXTY5cycling.com
3SIXTY5cycling.com
Is that bulbous front wheel modeled after a Pino Moronni design?
wow - what size are those wheels?!
"Are you sure we're going fast enough?" - Emil Zatopek
Hey Dan, did USAT or USCF ever get on your case about the carbon fiber "gusset"?
http://web.archive.org/...orld.com/gusset.html
Want: 58cm Cervelo Soloist. PM me if you have one to sell
Vintage Cervelo: A Resource
Pffft! That guy looks like a lifeguard, not a triathlete. ;)
"100% of the people who confuse correlation and causation end up dying."
Re: Retro TT stuff [Johnny99]
1994 Evgeni Berzin used it in the time trials at the Giro.
Re: Retro TT stuff [vikingstumps]
You could start with this design and make a few improvements and have a very nice bike. 3 to 1 tubes all around, rear brake hidden, internal run cables, ISP to keep it clean at the seat, aluminum would work but carbon to get better tube shapes and have different lay up in areas.
Zipp's Josh Poertner still speaks highly of the aerodynamics of the Zipp frame, but laments the money-losing aspects of it.
1994
1994 Moser hour TT
1993 Obree
1994 Moser hour TT
1993 Obree
lacticturkey: Mar 16, 10 14:53
Re: Retro TT stuff [campled]
Any information on those cranks? Curious about what the supposed advantages were/are.
here's a pic you posted in another thread of those front brakes:
Re: Retro TT stuff [wasfast]
Probably trying to eliminate the "dead spot".
Those cranks are for people who don't understand geometry and load paths...
"The torque, specified with regard to the axis of rotation, is equal to the magnitude of the component of the force vector lying in the plane perpendicular to the axis, multiplied by the shortest distance between the axis and the direction of the force component. Regardless of its orientation in space, the force vector F can always be located in a plane parallel to the axis."
in short ... psyches you up and psyches other out ;)
Silva aluminum disc wheels
lacticturkey: Mar 18, 10 9:18
These are the rear brakes, Using Shimano's old aero brakes. Way before Felt put their brakes below the bb.
Regarding the cranks, this is what the owner sent me (an expat residing here in the Philippines but works in KSA)
great looking bikes ... for the PMP crank, is the BB to spindle distance still around 170 mm ?
lacticturkey: Mar 19, 10 1:31
Re: Retro TT stuff [lacticturkey]
These were branded "Rider". Had one in the past with some flames paintjob!
Never get the hag of it, but it was a nice looking frame.
_______________________________
The "Pocket Hercules" - jgrat
Technique sets the upper limit to where your fitness will take you...
Not to nit pick, but what you mean is, Those are rear brake below the bottom bracket. Way before Felt put their brakes in the rear wheel fairing behind/above the bottom bracket.
