Re: Kestrel Wind tunnel data [Dave Luscan] [ In reply to ]
In Reply To:
A little birdie told me that "things were done very fairly to all bikes in the test. The Kestrel is quite impressive" This little birdie was very close to the action and impartial.
If this were the case, then why would they not release a detailed testing protocol? Failure to provide data is always a bad thing.
Re: Kestrel Wind tunnel data [Andrew V] [ In reply to ]
In Reply To:
steve h (sharad here) promised us at the show that they would publish the details and as TomA mentioned be as transparent as possible.
He did say he was looking forward to the st thread on the topic, so I assume he is watching this (hi steve!) and will chime in eventually...
G
greg
www.wattagetraining.com
In Reply To:
Then how does one explain the extremely high drag for the P3? The only answer that really makes sense (and is consistent with both Steve H.'s interview and the description on the graphic from xtri.com) is that it was tested with stock wheels.
BTW, does anyone know if the 4000 is UCI legal? I've received conflicting opinions...
In Reply To:
But . . . but . . . but . . . Dr. Coggan implied otherwise!?!
""things were done very fairly to all bikes in the test"
Fairly is a relative term, depending on the philosphy used during the testing. Most companies are controlling out the non-proprietary gear to the greatest extent possible. In the absence of information about the specific setups on the bikes in the graph, and given the statement about essentially stock bikes, Kestrel appears to have changed that philosophy to be able to say "Look, the bike we give you at our MSRP is faster than the bikes these others give you at their MSRPs." (I'm still holding out that even if they took that tack, they would at least control out the wheels since those are the most likely suspects to be changed out by consumers in a race situation...and since, as others have noted, deep aero wheels vs stock aluminum clincher wheels leads directly to complete non-sequitur with this data set).
If that is, in fact, the case, as a consumer, I can appreciate that approach...even if the engineer in me wants to crawl down into the weeds and demand a complete apples-to-apples approach, since I'm unlikely to buy a stock bike anyway. I mean...take a look at any P3-infested transition area. By and large what you'll find are stock P3s with some Zipps, Heds or somesuch for wheels. Same with Spec transitions, Felt DAs, etc. So apparently, the average consumer isn't inclined to take the time to dig into each and every part of a bike's setup to determine the efficacy of the system. All they are concerned with is which of the bikes is going to be faster when they stick their Zipp 808s on it. That involves the entire system, not just the frame and proprietary fork, seatpost, headset, and/or stem.
Just a loose thought train... while I take a break from the engineering weeds here at work! ;-)
Re: Kestrel Wind tunnel data [ndenezzo] [ In reply to ]
In Reply To:
Ok, so I may have exaggerated a little bit. I do trust the manufacturer data enough to place each bike into a specific category (in this case, the P4, Kestrel, Shiv, Giant, Trek SpeedConcept, etc. category).
Ummm...I don't know if I'd place the 4000 into that "upper tier" just yet, especially based on that chart...since none of the others were represented and it's unknown what wheels were on the P3.
In any case, people are losing sight of some other bikes on there and how the data can be placed in context. For example, the Airfoil Pro "as recieved/tested" has values that are VERY similar to those shown for that bike in the Cervelo data that was assumedly run with deep wheels on the bikes (we know at least the airfoil had a rear disc). In that case there's an ~80gf difference at zero yaw between the Airfoil Pro and the P3. Judging by THAT, from what we know now (and making the reasonable assumption that the P3 in the Kestrel test was run with Shimano R-550 wheels) I'd put the 4000 more in the P3, P2, DA, TTX, Transition "tier" of bikes...which actually matches my "gut feel" of where it would fall when looking at the frame in person.
So...I'm going to go out on a limb here and guess which models of each bike were tested by Kestrel:
2009 P3
2010 Kestrel 4000 LTD
2010 Fuji D-6 RC Matt Reed Edition
Kestrel Airfoil Pro Special Edition
We'll see how well that matches up when (and if) that info is finally revealed ;-)
Re: Kestrel Wind tunnel data [TriBriGuy] [ In reply to ]
In Reply To:
Assuming (always a dangerous thing) that was indeed their thinking and how the bikes were tested, then it would also only be fair to list the MSRPs:
Kestrel 4000 LTD: $10829
Cervelo P3: either $3600 or $4500 depending on spec
So IOW, you could buy two Ultegra-equipped P3s and a set of Zipp race wheels for the price of the Kestrel, have one bike for training and one just for racing, and likely not give up anything in the aero drag department...
Re: Kestrel Wind tunnel data [Tom A.] [ In reply to ]
You've seen a 4000 in person, Tom?
In Reply To:
Yup...touched it too...while I was standing next to, and conversing with, Steve Harad :-)
Re: Kestrel Wind tunnel data [hgrong] [ In reply to ]
In Reply To:
In Reply To:
It was actually ATC who first suggested that perhaps the bikes weren't fitted with the same wheels:
http://forum.slowtwitch.com/...post=2534689#2534689
All I've said is that explanation makes sense given the high drag for the P3, the statements on the original graph, and Steve Harad's interview on xtri.com. If there is some other logical explanation, then I'm all ears...
In Reply To:
I guess that all depends on your (or the birdie's) definition of "fair"...
In Reply To:
In Reply To:
Ah, so that explains it - should we start calling you Midas now? ;-)
Re: Kestrel Wind tunnel data [Andrew Coggan] [ In reply to ]
In Reply To:
In Reply To:
In Reply To:
Trust me, if you see how most of my projects around my house have been turning out lately...you'd start calling me the "anti-Midas" :-)
In Reply To:
In Reply To:
In Reply To:
In Reply To:
Everything has been turning into lead, eh? ;-)
Re: Kestrel Wind tunnel data [gregclimbs] [ In reply to ]
In Reply To:
In Reply To:
G
Yeah...he DID say he somewhat enjoyed spinning up us "propeller heads" a bit, didn't he? Hi STEVE! :-P
In Reply To:
2009 P3
Doesn't that version of the Fuji come with high-zoot aero wheels? Based on the data, I'd expect it to have been tested with wheels similar to those on the P3.
In Reply To:
In Reply To:
2009 P3
Yup...1080s...that's why I guessed that one. Has any other data you've seen on the D6 been "bike only" (like apparently this data is)?
In Reply To:
In Reply To:
In Reply To:
2009 P3
So you're saying that you think a Fuji D-6 needs to be fitted with Zipp 1080 wheels to match the drag of a Cervelo P3 fitted with Shimano R-550 wheels? I haven't seen any bike-only data to suggest otherwise, but still...
There is absolutely no way that they bikes were tested with different wheels. It IS entirely possible that they were tested with the wheels that made the Kestrel bicycles look the best, but surely they were identical across the 4 models.
On the topic of the Cervelo data on the P3 vs Airfoil, I suspect that was done with the 2008 model of Airfoil, so the only constant between this new test and the Cervelo data is the P3 itself. Unfortunately that hasn't left us with much to go on.
Chris
In Reply To:
In Reply To:
In Reply To:
In Reply To:
2009 P3
Judging by the width of that seat tube/brake area, along with the "truncated" back half...oh, and also that silly behind the fork brake (with the attendant brake housing hanging out in the breeze)...well, yeah...let's just say I wouldn't expect it to be close to a P3C with the SAME "low line" wheels on both ;-)
In Reply To:
In Reply To:
I don't understand the gripe here. They put on the graph that they tested the bikes as they would be delivered to the consumer. This would imply stock wheels for all the bikes. This seems like a fair test when directed to the consumer who isn't interested in and doesn't want to spend a couple of thousand more bucks after receiving the bike in order to make it even faster (probably the majority of them, none of whom hang out here).
Frank,
An original Ironman and the Inventor of PowerCranks
Re: Kestrel Wind tunnel data [chicanery] [ In reply to ]
In Reply To:
Ummm...how do you square your opinion with this quote from Steve Harad (bold added)?
Quote:
Well, we are going to put the wind tunnel data out shortly and Xtri will get the information right after Interbike.. Just know that we not only tested 20% faster then the Cervelo P3 and we also believe we have come up with the standard on testing. The concept is that I want to test bike vs. bike. Exactly how the consumer gets it. No cheating. It is helpful to the consumer to see what the bike on the floor of the bike shop tests, not just the frame or a partially assembled bike.
In Reply To:
In Reply To:
In Reply To:
In Reply To:
In Reply To:
2009 P3
How about the same "high zoot" wheels and a rider aboard?
In Reply To:
Before or after bikes get shipped to Rwanda? ;-)
In Reply To:
In Reply To:
In Reply To:
In Reply To:
In Reply To:
In Reply To:
2009 P3
Then...all bets are off...
