What's your favourite thing to use to cover up superficial wounds, following a crash? You know...random example, a big red patch on the hip area....the one that sticks to your underwear, and when you take the underwear off, you cry like a little girl, seeing the skin being peeled off...
Re: Crash, skin, fix [Francois]
forget the hip. Is the Argon 18 E-112 okay?
-Adam
http://www.austintricyclist.com
Facebook http://www.facebook.com/austintricyclist
Twitter: http://twitter.com/#!/ATCTriShop
-Adam
Re: Crash, skin, fix [ATC]
of course...brake lever a tad bruised, but no paint chip, thanks to my careful body sliding under the frame :)
Go to Walgrens and get "Second Skin".
There's a clear bandage that has "sticky" only on the edges. The middle just covers your booboo. Keep it covered, it'll heal from the inside. If it scabs over .... scrape it off. Keep it soft and covered.
Paul
Paul
Re: Crash, skin, fix [zipp]
tried that stuff before, and never found it particularly effective.
Tegaderm (relatively easy to find) or better yet, duoderm.
Fatigue is biochemical, not biomechanical.
- Andrew Coggan, PhD
Tegaderm....it can even be "shingled" to cover over injuries larger than the individual sheets. Just make sure that the adhesive edges are either on clean, dry skin or another sheet (if shingled).
If you do it right, you should be able to leave it on for a couple of days and even take showers with it on. If the wound is "weeping" significantly, "draw" a line of antibiotic ointment across the lower edge of the sheet (to prevent it from sticking there) and then tape a gauze pad at that "drain" you just created. It's a LOT easier to just change that one gauze pad that's NOT stuck to the wound ;-)
Tegaderm.
If you know anyone who works in a hospital they can get large sheets of it.
will fill with fluid on road rash but works great and allows the wound to Breathe
These guys, and some tape, ace bandage or net bandage to hold them in place:
http://www.americarx.com/Products/6328.html
Carrington Gel, a burn treatment that works very well.
Here's some info:
http://www.bikesportmichigan.com/features/roadrash.shtml
Tom Demerly
The Tri Shop.com
Here's some info:
Tom Demerly
The Tri Shop.com
Forget speedwork. Speedwork is the icing on the cake and you don't have a cake yet. - MattinSF
Basically they have 9 tenants, live life to the fullest, do not turn the cheak, and embrace the 7 deadly since. - TheForge (on satanists)
Re: Crash, skin, fix [Lazy Ben]
I'm gonna go with that, and a side of tegaderm ;-)
mmm-mmm-Momo Charms
Handmade beverage charms, jewelry, and miscellanea
http://momocharms.wordpress.com
mmm-mmm-Momo Charms
Damn, that stuff stings!
-Jot
-Jot
