Wolf fork failure (pics)
Ouch ...
Well, only some minor road rash to add to my lovely knees. Broke just like Hincapie's did at Paris-Roubaix I think (right blow the stem) The details:
Wolf SL (all carbon) on a Cervelo Soloist Carbon. About 8,200 miles on the fork. Installed per instructions with the epoxied aluminum insert at a reputable shop (bout new at my LBS). VERY short (I run no spacers at all). FSA OS 115 stem torqued to spec. 155-165# rider. Stopped at an intersection, heading for some hill riding (Indian hill area of course for the Cincy peeps). Started and torqued the bars some to get a jump through the intersection at the green light - SNAP! Down, right in the middle of the intersection. Just about got ran over by the minivan behind me (tire about 2 inches from my leg). Didn't know what happened.
Funny part was after the "rescue me" call to the Mrs., a biker comes by to ask if I was OK. He was a BIG guy on a new looking cyclocross bike that he hopped a few curbs and things to get to me. He chuckled seeing me in my roadie kit and my ultralight (15.6 lbs) Cervelo with the steerer snapped. He probably wouldn't have stopped at all if I was in my Tri get up and tribike! We chuckled a sec about our *differences* before he spun off ...
Anyway, any fork recs from the Slowtwitch braintrust? Time to do some *research* ... Easton, Look, Reynolds?
Fatigue is biochemical, not biomechanical.
- Andrew Coggan, PhD
Re: Wolf fork failure (pics) [rroof] [ In reply to ]
Wow, good thing that you were not hurt worse. I have seen that before on AlphaQ and on a Wolf...plus for some reason the AlphaQ plus had been known to creak at the insert. I may be just a nut and wrong about this...but I will only ride a woven carbon steer tube. Not sure it is any safer but I feel that if it was to fail the weave may just keep the works not falling off.
Re: Wolf fork failure (pics) [Record10Carbon] [ In reply to ]
Yeah, could have been a LOT worse. I was only 4 miles from home, but also only about 1 mile from a 45 mph downhill! After that, it was to be up, down, hill repeats, etc. Could have been ugly.
I'm not *down* on the fork at all - great fork, and I know parts fail (esp carbon ones) but I think I'll shy away from a Wolf or AlphaQ ultralight fork. I think I'll still go all carbon (maybe) ;-)
the obvious: you are very, very, lucky.
talk to the big C, maybe they'll help you.
and try to get a fork with an AL steerer.
Where would you want to swim ?
Re: Wolf fork failure (pics) [GregX] [ In reply to ]
I agree.. is the weight savings of a carbon steerer worth that kind of risk? Aluminum is so reliable for parts like that . Im just not enough of a weight weenie to care personally.
Glad your OK!
Time to go check my fork! Luck is on definitely on your side today. I ride an Easton EC90 SLX (bike came with it), but I've heard rumours that there are some issues with it. Haven't been able to find any hard facts on it though. I have about 10k miles on it and it still rides great with me being harsh on the roads bumps and potholes.
Having said that, does anyone know how often you should replace a fork (if any)? My next one will probably be a Reynold's with an alu steerer. Screw weight savings...
"Yeah you point a finger back far enough and some germ gets blamed for splitting in two."
Colonel Saul Tigh from Battlestar Galactica
i've read about this with the Wolf SL before, and i would think it's a warranty issue. Having said that, if you have lost confidence in the Wolf SL, and you still want an full-on aero fork then do consider the Blackwell Research forks. I own the non-UCI legal Bandit and the steerer tube is the thickest i have ever seen. Not very light obviously but ok for so much material. Other aero forks to consider would be the Edge Composites aero fork, the Reynolds Ouzo Pro Aero (which tests very well incidentally). For non-aero, consider the Look HSC 5SL, Ritchey WCS or Easton EC90SL.
Dude, that sucks! Glad to hear you're OK.
Spot
___________________________________________________
Taco cat spelled backwards is....taco cat.
glad you are safe
Striving to have sex more than 66 times per year
Man ... I'm really glad you're OK.
I was going to tell you that I don't do carbon steer tubes, but Trek just sent me out an '07 Madone 5.2sl frameset/fork as a warranty replacement for an old OCLV that developed a crack. I don't know what's on that Madone. I'm certainly going to go check.
Funny, I just saw a video of Hincapie's Paris Roubaix "look Ma, no bars" moment yesterday.
Heal up quickly!
Bob
Glad you're OK. Carbon scares the crap out of me. A friend's cyclocross handlebar failure. He was lucky too.
It doesn't say anything on pg 15 of the cervelo owners manual about minimum stack height (spacers below stem) but many fork companies recommend a minimum. I don't know why some companies do and others don't.
Re: Wolf fork failure (pics) [psycholist] [ In reply to ]
Thanks all -
Bob - I'm not all that gung ho on carbon parts either (I'll never understand carbon bars and stems since they are no lighter anyway), but Hincapie's steerer tube failure was a steel (or aluminum) one, and not carbon! I've heard that carbon parts don't necessarily fail any more than metal ones, but installation/torquing instructions are more critical. I'm not sold yet, but 200g and a nicer ride (I think I can tell) and I'm light still points me to an all carbon fork ...
Well, got some research done now. This might help some people. What I have learned (all high end forks).
ONLY difference between the Wolf SL and CL is the carbon vs. steel steerer tube.
The new Reynolds UL (needed since their very nice Ouzo Pro/Peloton forks haven't upgraded in a while and many forks are now much lighter) has a recall
The Easton EC90 SLX tests poorly with lateral rigidity (German Tour magazine), but is under 300g
I can find very little real data about the Edge composites forks or where to buy.
The Blackwell forks don't belong on my road bike!
The LOOK HSC 5SL is also under 300g, tests well with stiffness, and has no reported failure issues that I could find. They just released a new HSC 6 that is 15g heavier, but even stiffer. This *LOOKS* (pun intended) to be my next fork ... but, they have an integrated crown at 36 degrees and I think the internal headset of the Soloist is the standard 45 degrees? What the? I can't seem to find out. Looking at it looks like the std. FSA/Cane Creek stuff (45/45). FSA site lists 45/36. Does that mean 45 degrees upper and 36 lower?
Re: Wolf fork failure (pics) [NTM] [ In reply to ]
Actually, if you dig, Cervelo recommends less than 80mm (std 15 top cap plus 3 10mm spacers, then stem) on the Wolf SL fork. This coincides with the 125mm aluminum sleeve that gets epoxied in during installation. There is no min for the CL. I was WAY below that though with only the 15mm top cap and zero spacers.
I'm getting quite the steerer tube education here (with ice on my knee) :-(
Anyway, for others that ride hard and have some miles on ... go check your steerer tubes tonight!!!
The HSC 6 fork can only work with the Look 595 and 586 i think. They have a unique structure somewhat like the Kuota fork, and so cannot work after market with other bikes, hence why i suggested the HSC 5.
Re: Wolf fork failure (pics) [Spoon] [ In reply to ]
You know how often I hear "wow, cant beleive you dont have a carbon handlebar"...yeah, I have full Record, nice wheels and a custom frame...I however like my teeth far too much to risk a carbon bar.
PLUS - a Deda Newton Alu bar weighs 35gm LESS than an EC-70 and just 5gm more than the SLX...for my 5gm I will put on a little less bar tape.
glad you are ok
I am keeping old school (bike weight with stuff 20 LBS)
steel is real
super chicken I am I am
I will lose the weight in my fat ass instead
Dan wrote on carbon light weight forks
i agree with you in principle, but your numbers are all wrong. i've never weighed a newton under 240g.
Re: Wolf fork failure (pics) [footwerx] [ In reply to ]
Picked the numbers Colorado Cyclist dot com. Not sure how valid they are.
Looks like you are having quite the time with your research. Have you come across anything in regards to the Profile Designs ADC All Carbon fork? Apparently its the official fork of Ironman (like that's a big deal, I can also go out and buy the official mattress of Ironman too). I have one, the fork that is, I'm about to install this week on my Cervelo P2C. All I see in the instructions is they say no more than 20MM of spacers between the headset and the stem.
I got a fantastic deal on the fork, brand new with an uncut steer tube for $130.00. All I need is a headset and I will be ready to build her up.
Cheers,
Dave
Dave Stark
dreamcatcher@astound.net
USAC & USAT level 2 certified coach
Re: Wolf fork failure (pics) [karma] [ In reply to ]
Profile forks you will have a hard time finding anything bad about - other than weight. Used to call the BDC "Brick Deep Carbon"...it was about twice the weight of other forks. I have ARC on my Bianchi fixie...in the hand it is my heaviest non aero fork (compared to Easton SLX, Look HFC, Ouzo Pro and even a Specialided OEM)
Rod-
Well, you are freaking really lucky that didn't happen further along on your ride. I don't even want to know how that could have turned out if it had happened by Her Honor's house!
You may have some outdated info on your fork installation. Go check out the Cervelo forum regarding "fork insert" and the Wolf SL. Spend a little time reading up on some of the posts and you will quickly understand that there is a great deal of confusion regarding the issue. My understanding is that Cervelo is now advising no more than 65mm stack height above the headtube, while Alpha Q/True Temper recommends no more than 70mm. This means that a 40mm stem + 15mm top cap+10mm spacer= 65mm and you are tapped out. The aluminum insert is only 75mm long and must extend 10mm below the upper headset bearing. There is no way that you could do that with 30mm worth of spacers. Check out the raging debates on the forum and notice the very different ways that the SL fork has been installed by shops depending on their reading of the instructions. Check out the posts from "Cervelocs" (I think)- he works for Cervelo and has attempted to clarify the instructions somewhat...and not very well I might add.
I don't think that this situation applied to you however. IIRC, you had no spacers, so not an issue. Just as an aside, I saw that Cervelo is now shipping the SL forks with 125mm inserts and that they are already installed. I am absolutely **shocked** that this is the first time that the topic has come up on ST. I still have a brand new Wolf SL sitting in my basement because I just don't know what to do with it. Cervelo, in my opinion, really dropped the ball on this one...
Re: Wolf fork failure (pics) [cincytri] [ In reply to ]
If they know that...why do they not ship the fork with it cut to the minimum? Not to hard to do that math.
Yeah, I was reading around on the forums there. Does seem like quite a mess for Cervelo - add the *shortage* of Wolf SL forks! Well, Josh, you are a LOT more timid and bigger than me, so I don't think I'd be installing that!
And yes, I was heading down to Spooky Hollow, Camargo, etc. My usual stomping grounds ... I'm sure one of the Bentleys or Rolls Royces would have just run me over like a speed bump there if I was splayed out on one of those hills ;)
Again, I think True Temper makes some OK stuff (Wolf, Alpha Q), but they, like other companies (now the Reynold recall) are pushing the envelop some.
I did think about the brick Profile Design fork (can buy 3 for the price of the HSC 5 SL), but ... nah! ;-)
