it musta been the 100k bars i have tried then also trying to stand out of a corner. 35mm wide is fine. most handle bars are just barely wider.
yeah those hooker bars were the del. Wasnt there a pro women at kona that didnt eevn have a basebar? custom Cat i think?
In Reply To:
In Reply To:
ya those are dope bars. heaven forbid you have to make any technical turns with them though. perfect for out and backs though.
The Extremes were 36 cm wide, which is more than wide enough to provide adequate control through tight turns, allow out-of-the-saddle climbing, etc.
The Scott 100k bars were significantly narrowerer, but were still wide enough for anything that didn't require getting out of the saddle.
The Hooker 'aero or die' bars were only ~15 cm wide, but many still used them even on technical courses.
I suppose it all depends on your perspective...
