vaseline vs chamois creams
Re: vaseline vs chamois creams [jackmott] [ In reply to ]
I use Aquaphor.
Pros:
It's a shitload less expensive than chamois creams
It has a healing/ointment element to it
Cons:
Favorite Gear: Dimond | Cadex | Desoto Sport | Hoka One One
When I started running and first experienced the effect of chaffing, I started with vaseline. It works great however, I realized all my shirts had two oily dots around the effected area that won't wash away with any detergent. Now these shirts are in the trash. Never tried it on chamios and didn't want to risk it on expensive cycling shorts.
Now I've been using butt'r and body glide.
I don't know the pros or cons from a use perspective, but as a petroleum jelly it wil not come out of clothing in the normal wash. So, if you're use it, you might have problems with build up on the chamois.
Bob
I get best results with bodyglide applied directly to my clothing and a "general" chamois cream over skin hotspots.
Re: vaseline vs chamois creams [3Dealz] [ In reply to ]
This also happens with udder butter. They work well, but man those spots are bad
If you're looking for something less expensive that "real" chamois cream, I use both A&D Ointment (the original yellow, not the white stuff w/ Zinc) and Noxzema. (I actually use the Walmart knockoffs of each.) The A&D I use for races and longer rides since it's a little thicker and stays on better. I use the Noxzema for shorter rides since it's less "goopy" and washes out easily. It's tingly, too! The white A&D w/ Zinc is too thick and clumpy, IMO.
Steve
"If you ain't first, you're last." Reese Bobby Talladega Nights
Re: vaseline vs chamois creams [The_Mickstar] [ In reply to ]
I second the A&D. Also if I get a "spot" I use Dr. Smiths diaper rash ointment and takes care of it.
I have been using bag balm for over 10 years for any ride over 3 hours. A 10$ box lasts 2 years.
http://www.bagbalm.com/download/bikemag.pdf
Francois in Montreal
Re: vaseline vs chamois creams [GMAN 19030] [ In reply to ]
I use vaseline for longer Tris as it's much more resilient to the water and likely to still be there after the swim. Besides, you can use it on your underarms neck etc to avoid other chafing areas; one product does it all. I've not experienced any degradation of 'chamois' or my wetsuit as a result.
29 years and counting
Re: vaseline vs chamois creams [Jorgan] [ In reply to ]
Instead of vaseline, why not try lantiseptic? It was made originally for bed sores.
A ounce of prevention is worth a pound of cure so I am more than happy to spend for chamois cream.
Right now, Sportique Century Riding Cream is my top pick. I just wait for a sale then stock up.
Re: vaseline vs chamois creams [fbrissette] [ In reply to ]
+1 I'm a big fan of the Bag Balm
Re: vaseline vs chamois creams [trimama] [ In reply to ]
A&D got all my kids thru diaper rash - great call!
Question, however: Does it not build up/stain the same way that other non soluble stuff (aquaphor, vaseline) do?
GMAN 19030 wrote:
I use Aquaphor.
Pros:
Cons:
+1 Aquaphor for reasons above.
My only issue is, it seems not water soluble, and so I worry about build up (and it is annoying to get off your hands, which you gotta do before you wreck other clothing)
I used chamois butter for any long runs or rides leading up to my first half marathon... morning of the race couldn't find the chamois butter so i had to use vaseline for the first time to prevent chafing. They did the trick but the tri shorts I wore during the race are too stained to use now other then a pair of compression shorts under running shorts.
And the stain doesn't come out with any kind of detergent.
For those that are really frugal there is always Crisco. I don't think you can get cheaper than that. It tends to break down pretty quickly, but they all breakdown fast relative to a 3 hour bike ride.
I have used it to prep my bike and run shoes for easier entry. I have a little plastic container that I spoon the Crisco into beforehand. It works pretty well. I can use it liberally without feeling like I'm wasting the stuff.
where do you buy Bag Balm in Canada?
Re: vaseline vs chamois creams [marky_sparky] [ In reply to ]
TSC stores sell it - http://www.tscstores.com/stage/index.php
cheers!
-mistress k
__________________________________________________________
ill advised racing inc.
I guess it really depends what you're into....
Many hardware stores have them and most (if not all) of the gardening stores have it (gardeners get cuts from flowers and use it as protection/healing aid). the odd local bike shop also have it. Very easy to find in Quebec, have no idea about other provinces.
bagbalm.ca sells it online.
First I have to hear about my mother in law rubbing horse cream for muscle injuries and now this. I think I need to go for a very long swim now!
This is the description of the product:
Quote:
Designed for dry, chapped cow udders, Bag Balm works great for any animal's skin Treat your pet's chapped or brush-burned area with Bag Balm for soothing, moisturizing relief. In case of deep puncture wounds seek medical help. Discontinue use if rash or irritation occurs.
I used vaseline when I started riding, and it worked well to reduce chafing, but it has two major disadvantages: It somehow got into the saddle and caused the leather/microtex on my Arione saddle to come loose. I suspect the oil it contains dissolves the glue they use. Secondly, as another poster says, it is impossible to get out of the chamoix of your shorts (using normal detergent). I use DZ Nuts, and it is by far the best I have tried (all the common ones). It may be expensive, but you aren't using very much, so a bottle lasts a while.
Re: vaseline vs chamois creams [johno2211] [ In reply to ]
chamois butter stays on during the swim, is easy to get off your hands and smooths things just fine. Anybody use the Mission stuff?
I use Sportique Century Cream.
Pros: 1. Stays on when wet,
2. works well on the bike; and
3. All natural ingredients.
Cons: 1. Expensive (~20 / tube)
2. Some aren't fond of the scent ( I don't mind it at all)
