So on a smart trainer you can set the power level in ERG mode - Setting a specific power level – i.e. 225w. In this mode, no matter what gearing or cadence you use, the trainer will simply stay at 225w (or whatever you set it to)
If you compare that to a dumb trainer, if you want to pedal 225 watts you have to find the gear and cadence that suits you. And more often than not the cadence for a specific power will not be your preferred {most efficient} cadence. You have to choose a gear that will give you a little low cadence, or one that gives a little high cadence.
A dumb trainer seems to me to mimic riding on the road much more realistically as the rider determines the power output, and has to utilise the gearing an cadence to generate power. With a smart trainer the resistance is always there provided by the trainer. To me this suggests that there would be some difference in the way muscles would be utilised to provide the power in each case.
So what I want to know is, do the two types of trainer provide a different training effect? If so, is one style of trainer more beneficial than the other?
I hope this makes some sense..
