Jim@EROsports wrote:
There are a few things I would comment on, though based solely on photographs with little background information, detailed analysis is somewhat folly.
You have a curved back because it's very likely you have...a curved back. Not everyone has, or should try to achieve, a flat back, nor is it necessarily the most aero set up anyway. Reach is good. Depending on whether or not you're taking your exception at the saddle or reach (almost everyone should be taking one or the other), you could try more reach, but it's not going to flatten out your back much.
The actual "most glaring" issue is your hands are below your elbows. The UCI now allows the tips of your extensions or, in your case, the tips of your shifters in line with your extensions, to be 10cm above the center of your arm pads. Tilt your extensions and pads to this point and you'll almost certainly get an aerodynamic gain as well as a more relaxed upper body. Tension is the enemy of CdA.
Buy a LG P09 helmet.
What are your experiences testing the P-09 Jim?
For somebody who won't have the opportunity to do anything more than try on before purchase, is it a relatively safe bet?
(long course tri, flat(ish) back, I'm generally quite low and am happy I can get the fairing against my back for a decent portion of the race)
