[reply]R853 vs. R851? Not much difference, IIRC, but I'm not sure I've ever seen a bike of R851. Now if you're talking 531 vs. 853, then you've got a decent jump in strength to weight ratio and stiffness with the 800-series.
7000-series Al is slightly stiffer and has a slightly higher strength to weight ratio over 6000-series.
[/reply]
With all due respect, this is simply not true. There is no difference in stiffness between different types of steel. The stiffness is constant for all steels regardless of the exact composition. The same goes for Aluminum, regardless of the exact alloy, the stiffness is identical. It is molecularly impossible for there to be a stiffness difference. Material science 101.
As for strength, since all frames eventually fail at the weld, the material strength is not nearly as important as the weld strength. And when it comes to that, weld design and execution is the driving factor, not the material.
Case in point, there are plenty of frames in Ti (6-4 ^ 3-2.5), Alu (6000 & 7000 series), carbon and steel that fail fatigue tests, and there are also frames in all four materials that pass them. And when you examine where they fail (as for example EFBe does independently from manufacturers), they always fail either due to a weld imperfection or a braze-on, like cable stops or a derailleur hanger.
Gerard Vroomen
3T.bike OPEN cycle
