My head unit is the 910xt. While on the trainer, well I get speed, distance data from the pt?
Re: can you get speed data from a g3 PT while indoors on trainer [avikoren1]
Sure you can. Just set the wheel size to manual and enter its circumference in milimeters. This is more accurate than GPS speed/distance anyway.
Go to page 19 on this PDF to learn how to do it: http://static.garmincdn.com/...nner_910XT_OM_EN.pdf
I am not sure about a g3 but my powertap SL+ does...
Joel
Joel
Re: can you get speed data from a g3 PT while indoors on trainer [joelt]
I have a G3 and a G3C - both do it perfectly.
Re: can you get speed data from a g3 PT while indoors on trainer [RichardL]
Thanks
You don't even need the speed magnet and sensor since the G3 knows exactly when the wheel has rotated one revolution.
Yes cool. But it can't do cadence right?
avikoren1 wrote:
Yes cool. But it can't do cadence right?It does cadence too. I found it tends to be a few RPM lower that the Garmin cadence sensor but accurate enough.
Rodney
TrainingPeaks | Altra Running | RAD Roller
http://www.goinglong.ca
avikoren1 wrote:
Yes cool. But it can't do cadence right?It does cadence, some people it will be pretty spot on almost all the time. But it can be completely wrong if you pedal smooth sometimes....at least with the G2 it would be for me.
I haven't actually checked that with the G3. It could be smarter!
Re: can you get speed data from a g3 PT while indoors on trainer [rbuike]
rbuike wrote:
yup, it reads the pulses in the power to estimate the cadence, not a perfect read, but close enough.
I reject your reality and substitute my own!
Adam Savage
Re: can you get speed data from a g3 PT while indoors on trainer [slidecontrol]
For me, cadence guestimate from the PT was unreliable, so I use Garmin wireless, magnet-less cadence sensor:
No more magnet to worry about.
