MAIN INDEX RULES & LEGEND LOG IN
Slowtwitch Forums: Triathlon Forum:
cadence
First page Previous page 1 ... 17 18 19 20 21 Next page Last page  View All
Frank Day
Oct 28, 09 11:34
Post #451 of 523 (2941 views)
Re: cadence [Andrew Coggan] [In reply to] Quote | Reply
In Reply To:
In Reply To:
In Reply To:
In Reply To:
I have also been able to copy this figure from the paper showing the UNLOADED energy cost (losses) with pedal speed. 290 watts are being required just to make the cranks go around
Metabolic watts.
Exactly what are metabolic watts? I have never heard of this term before? Wonder what it could mean? Perhaps it is the watt equivalent in energy consumption needed to turn the legs unoaded (since it is impossible for them to generate any real watts since the bike is unloaded so can do no real work) so it is easier for the reader to compare apples and oranges. What do you think?
You guessed correctly: metabolic rate measured in watts. For comparison, standard resting metabolic rate for a 70 kg person would be ~80 W.
So, you haven't answered any of the questions put to you above. Do I need to repeat them?
Just start with why you think it reasonable, if you want to examine the internal losses in a system, that it is perfectly ok to use a model that uses imaginary materials that prohibit internal losses? How does one use a model that doesn't look at something to reach accurate conclusions about that very thing? I am all ears perfessor. Anyone with an answer can chime in here if they want.
Frank,
An original Ironman and the Inventor of PowerCranks
Andrew Coggan
Oct 28, 09 11:39
Post #452 of 523 (2939 views)
Re: cadence [Frank Day] [In reply to] Quote | Reply
In Reply To:
Why don't you tell everyone here how one should design a model to look at potential internal losses.?
Well, what I would do is quantify the overall rate of energy production (release, really) using indirect calorimetry, then compare that quantity to:
1) the power that is generated by the limbs (determined using inverse dynamics), and
2) the power that makes it to the pedals (using either force pedal data or simply the power setting of the ergometer).
If you call the first quantity above A, the second B, and the third C, what I would predict* is that:
A > B ~ = C
demonstrating that the primary source of inefficiency is "upstream" of the point at which the limbs begin to move, and not "downstream" as you have continually emphasized.
Then again, what do I know? I'm just a "scientist"...
*Of course, this is a safe prediction to make, since it is what has been shown in the research literature.
Andrew Coggan
Oct 28, 09 11:43
Post #453 of 523 (2934 views)
In Reply To:
Because the materials in question don't deviate far from perfection.* Specifically, neither joint friction nor limb bending represent a significant energy "sink" - if they did, models based on assumptions of perfection wouldn't be able to predict actual data with the accuracy that they do.
*BTW, if you want to drive a biomechanist mad, start asking questions about "floppy masses". ;-)
Frank Day
Oct 28, 09 11:50
Post #454 of 523 (2928 views)
In Reply To:
In Reply To:
your answers only confuse me. So, you are telling me that you are using a model that doesn't allow any internal losses to be the basis for calculating real world internal losses using inverse dynamics?
You're right, the way that I stated it was confusing. What I should have said was that that hypothetical scenario has been repeatedly presented so that you will understand how the sources of various losses can be quantified (using inverse dynamics). Specifically, by recognizing that - in the absence of friction, limb bending, etc. - there is absolutely no energy lost in the interconversion of potential and kinetic energy, you would now be in a position to apply this correct understanding of the fundamental physics to the in vivo situation. However, despite your grudging acknowledgement that you have been wrong all along regarding the basic physics ("...for the sake of the present discussion..."), I still don't think you really get it.
Again, how do you use a system that prohibits limb bending (or soft tissue deformation) to evaluate a system that does. One can eliminate friction, or material deformation, or anything else, in the model if one wants to try to isolate the various areas of loss. But, isolating an effect requires that effect be kept in the model. It seems unreasonable to use a model that eliminate every possibility of loss to try to examine the magnitude of the various losses that the 2nd law dictate must be there. Using such a model dictates you get an answer (zero losses) that violates the second law (even though your starting point may not. No one, except me, seems to have noticed this little "problem."
The purpose of modeling is to help one better understand the real world. Using an unsuitable model, as you and everyone else has here, has simply made everyone's understanding worse because it has come up with an answer that cannot be true (it didn't look at anything "real world") and violates a fundamental law of thermodynamics and yet, "everyone" insists it is right.
In Reply To:
In Reply To:
Exactly how is that done?
Force pedal measurements + high speed film + knowledge of basic physics = ability to quantify the power "flow" through the ergometer + rider system. What such measurements reveal is that there is very little inefficiency "downstream" of when the limbs are set in motion - rather, essentially all of the inefficiency arises "upstream".
Very little is not zero. And, the data of McDonald suggests there are substantial losses, the unloaded losses are almost 300 watts under certain conditions. The smallest losses they encountered was about 70. You, and everyone else, have had to go through all sorts of mental gymnastics to make the data fit your unsuitable model (loading the chain suddenly makes the losses go away). It is bizarre to me that you would still be supporting this model for determining internal losses.
In Reply To:
In Reply To:
Exactly which physiological data did I insist on dragging into the discussion that is making it impossible to differentiate this stuff?
Martin's.
Ugh, which data is that?
Frank,
Frank Day
Oct 28, 09 11:58
Post #455 of 523 (2924 views)
In Reply To:
In Reply To:
Well, unless your model allows you to specify the degree of "perfection" of your material one cannot know how much effect there will be. You simply think the materials are almost perfect, which in your mind means the losses must be small, so you have decided to use a model that ensures you get an answer that is close to your bias. Some science that is.
For a model to be good it should give results that are close to experimental data. Let's examine the results your model would give for a real world cyclist and compare them to the experimental data. We will use their unloaded data.
condition, MMF losses, experimental losses
low pedal speed, 0, 70 watts
high pedal speed, 0, 290 watts.
Hmmmmmm. Correlation doesn't seem to good here. Maybe the model needs to be "tweaked" a bit.
Frank,
Andrew Coggan
Oct 28, 09 12:14
Post #456 of 523 (2915 views)
In Reply To:
The way you use any model (no model is ever a perfect representation of reality, but that doesn't mean that they are useless/provide incorrect answers).
In Reply To:
As I said before, you shouldn't be looking at data for the cost of unloaded pedaling in the first place. Be that as it may, an increase in metabolic rate from ~80 W at rest to ~290 W when pedaling at 100 rpm against no load using 190 mm cranks is hardly what I would consider "substantial", at least given the task. (By comparison, my metabolic rate when TTing is 1200-1500 W.)
Andrew Coggan
Oct 28, 09 12:15
Post #457 of 523 (2912 views)
In Reply To:
In Reply To:
In Reply To:
The predicted metabolic cost of "unloaded" pedaling is not zero.
Andrew Coggan
Oct 28, 09 12:23
Post #458 of 523 (2902 views)
In Reply To:
You mean like this? <g>
(From Neptune et al., 199X)
Note: J1 and J2 are two independent criteria used to optimize the model by altering the timing of muscle activation, whereas "subjects" represents actual experimental data (n=12, IIRC).
(This post was edited by Andrew Coggan on Oct 28, 09 12:24)
Frank Day
Oct 28, 09 12:25
Post #459 of 523 (2898 views)
In Reply To:
In Reply To:
In Reply To:
In Reply To:
That is what your model predicts it would be. A chain attached to a wheel does not require the wheel to be loaded. The KE is available to move back and forth, even when the wheel is unloaded because of the energy contained in the wheel. No different than the condition used in the lab.
A model, if valid, should work in all conditions. Einstein's model of the universe is expected to work under all conditions. So far Einstein has held up pretty well. Much better than the MMF model. One comparison and it doesn't look too hot as a predictor. Tell me again why this model is so good?
Frank,
Frank Day
Oct 28, 09 12:28
Post #460 of 523 (2896 views)
In Reply To:
In Reply To:
Is that from the MMF model? I suspect not since it is referring to muscle activation and according to the MMF model, not muscle activation is required once up to speed. Can we restrict this discussion to the MMF model?
Frank,
Andrew Coggan
Oct 28, 09 12:29
Post #461 of 523 (2893 views)
In Reply To:
In Reply To:
Not "my" model, and no, it does not. That is, once again you are confusing physics and physiology.
Andrew Coggan
Oct 28, 09 12:30
Post #462 of 523 (2892 views)
In Reply To:
Sheesh, Frank...haven't people been asking you to do exactly that for about 6 pages now?
Frank Day
Oct 28, 09 12:31
Post #463 of 523 (2890 views)
In Reply To:
In Reply To:
You might want to put a PowerCranker on that graph and see how close the model comes. Something tells me there would be a substantial deviation from that predicted line. A good model needs to predict correctly under all conditions. That looks good for the two cases studied. Need a lot more to say it is a great model.
Frank,
Frank Day
Oct 28, 09 12:35
Post #464 of 523 (2885 views)
In Reply To:
In Reply To:
In Reply To:
Just above you said you needed to use that model to analyze pedal losses. I consider it your model. You may not have "invented" it but you are defending it and you are telling me you use it. And, it does predict zero losses for the unloaded condition. If not, how is that the case? Show your work.
Frank,
Andrew Coggan
Oct 28, 09 12:49
Post #465 of 523 (2874 views)
In Reply To:
From that predicted line? Of course, because said line assumes that the cranks are coupled.
In Reply To:
N=12, actually.
In Reply To:
Then I suggest that you search PubMed for articles by Hull, Kautz, Neptune, Martin, Broker, Ingen Schenau, and/or any of the other dozens, if not hundreds, of biomechanists who have applied inverse dynamics to the pedaling motion.
Andrew Coggan
Oct 28, 09 12:53
Post #466 of 523 (2868 views)
In Reply To:
In Reply To:
In Reply To:
In Reply To:
Again, you are confusing physics and physiology: the little stick person pedaling with his/her perfectly rigid limbs and his/her perfectly frictionless joints in a complete vacuum has no muscles, but once set in motion by an outside force will pedal forever. OTOH, the model that Neptune used to generate the data in that figure includes 14 different muscles, each one of which has its own unique activation dynamics, speed of shortening, etc. While AFAIK it has never been used to predict, e.g., the pattern of force application or the energetic cost of "unloaded" pedaling, it will obviously not be zero as you have assumed, if only due to the "floppy" ankle joint.
Frank Day
Oct 28, 09 13:00
Post #467 of 523 (2861 views)
In Reply To:
In Reply To:
In Reply To:
In Reply To:
In Reply To:
What on earth are you talking about? Compare the predicted losses of the MMF model to those experimentally measured by McDonald. Defend your use of the MMF model to predict the energy cost of simply moving the pedals. The MMF model predicts zero energy cost. Experimental data measures substantially different values. Defend your continued use (and defense) of that model despite the fact that the data suggests it sucks as a model (at least for this purpose).
Frank,
Frank Day
Oct 28, 09 13:07
Post #468 of 523 (2853 views)
In Reply To:
In Reply To:
In Reply To:
N=12, actually.
In Reply To:
I don't have a problem with inverse dynamics. I have a problem in using inverse dynamics in a model that prohibits internal losses to predict real world internal losses. The fact you can make the math work is not evidence the results have any validity in the real world. Defend the use of the MMF model in predicting internal losses in the real world. You have told us it is the way you and, apparently, everyone else does it. It is the model you used to "debunk" my claim that there are internal losses. Defend the basis of your criticism of my point. There is zero evidence to validate the model for this purpose.
Frank,
Andrew Coggan
Oct 28, 09 13:19
Post #469 of 523 (2842 views)
In Reply To:
[I don't have a problem with inverse dynamics. I have a problem in using inverse dynamics in a model that prohibits internal losses to predict real world internal losses.
Inverse dynamics doesn't prohibit internal losses.
Andrew Coggan
Oct 28, 09 13:20
Post #470 of 523 (2840 views)
In Reply To:
Now why would I want to do that, since they are two different things?
Frank Day
Oct 28, 09 13:59
Post #471 of 523 (2820 views)
In Reply To:
In Reply To:
No, the MMF model that you are using does. Have you figured out your problem here yet?
Frank,
Frank Day
Oct 28, 09 14:03
Post #472 of 523 (2953 views)
In Reply To:
In Reply To:
Correct, why would one want to use a model that really doesn't predict anything in the real world to predict real world results? Of course, I guess it could be useful to try to shoot down the opinions of others who are trying to comment on real world results before a group of people ignorant of the deficiencies of the model. Could make one look smart and important until the fact that the emperor is not actually wearing any clothes happens to get mentioned.
Frank,
gciriani
Oct 28, 09 14:09
Post #473 of 523 (2948 views)
In Reply To:
In Reply To:
Andrew Coggan:
Frank Day:
Frank,
The MMF was modeled without losses. But one could model losses into it and obtain a MMF-cum-losses just by introducing a viscous element between two sticks. This is what tigermilk was trying to explain to you when he talked about modeling software such as ADAMS. Engineers (and researchers) do this every day: they keep adding additional features to their models to see how they behave.
Giovanni Ciriani
http://www.GlobusSHT.com
Andrew Coggan
Oct 28, 09 14:35
Post #474 of 523 (2929 views)
Let's try going back to the beginning...
This thread took off in this direction when the question was raised as to why efficiency decreases at some cadence above the optimum. As you have for many years now, you claimed that this was due to an obligatory loss associated with the intra/interlimb exhange of potential and kinetic energy that scales with the square of the cadence. The little stick figure with infinitely rigid limbs and frictionless joints pedaling in a vacuum was then introduced to demonstrate that your claim is based on an incorrect understanding of the physics involved. That is the sole purpose of this "thought experiment", i.e., it is not meant to reflect reality, and is not the model used by, e.g., Neptune.*
Ass u ming that you have now accepted that you are wrong, you should be able to at least appreciate that it is possible to accurately quantify the energy "flow" while pedaling based on fairly simple Newtonian mechanics. What such inverse dynamic calculations reveal is that of the power that is produced/absorbed across the hip, knee, and ankle joints, >90% of it makes its way to the pedals. Since thermodynamic efficiency is <<90%, this demonstrates that the primary energy loss occurs (as I have said several times now) "upstream" of the point at which the limbs are set in motion, rather than "downstream" as you have claimed.
*The data of Neptune that I posted are actually derived using forward dynamics.
(This post was edited by Andrew Coggan on Oct 28, 09 14:36)
Frank Day
Oct 28, 09 15:02
Post #475 of 523 (2912 views)
Re: cadence [gciriani] [In reply to] Quote | Reply
In Reply To:
In Reply To:
In Reply To:
Andrew Coggan:
Frank Day:
Frank,
The MMF was modeled without losses. But one could model losses into it and obtain a MMF-cum-losses just by introducing a viscous element between two sticks. (yes, but nobody did in making their argument, the nonsensical rigid MMF was good enough for them) This is what tigermilk was trying to explain to you when he talked about modeling software such as ADAMS. Engineers (and researchers) do this every day: they keep adding additional features to their models to see how they behave.
A model is used to try to understand things that are otherwise difficult to understand and predict. We have models for the weather. Models for electronics. The only useful purpose for a model is to help one better understand the world around them and the things they work with. Bicycles and riders are made of real world materials. While a model that eliminates all friction and all real world materials might hold some intellectual curiosity (might even be useful as a "character" in a science fiction novel) it it totally useless to predict any behavior in the real world.
If you take the perfect MMF and add friction to the model one might be able to understand how much friction is contributing to pedaling losses. If they are found to be small then we can understand that there may not be upside to spending a lot of time trying to reduce friction losses (probably not much can be done about them anyhow). Or, we can take the perfect MMF and add material losses to see what happens. Then, we would know how much this contributes to the loss. Is there any benefit to making the bike out of a "stiffer" material or one that is less stiff but has more energy return (a better spring, so to speak). Or, if the losses vary with the square of the cadence, how much can be gained from reducing the cadence. Put these two models together and one should be able to predict the McDonald data pretty well if the models are any good. If these data cannot be predicted well then either one or both models need to be improved.
What is simply amazing to me is that all you very smart people seem to not have a clue as to how to model anything around the bicycle and to how worthless the perfect MMF model is to this discussion, which is about real world losses, and how it was being used to attack my point. It is like you are all hell bent on proving whatever I say wrong, regardless of how it is done. (If I am ever allowed to be right about anything it might mean I could be right about PowerCranks, I suppose, is the thinking.) People kept at it even though I pointed out that their solution violated the 2nd law. Unfortunately for you folks, I am not cowed very easily when I am pretty sure of my position. I think I have been proved right here and several of you owe the ST community (I could care less about myself) an apology for forcing this fallacious thinking down their throats for the last several years, whenever this came up.
Frank,
The New Specialized Wind Tunnel
Will this be a game changer for Specialized, in both sales and product design, or will it not move the sales and design needle versus those in Specialized's competitive set?
Yes, Game Changer
Minor move forward
Won't budge the needle
