In Reply To:
A few comments:
1) Are you now admitting that a frictionless, perfectly rigid stick figure pedaling in a vacuum would continue to pedal forever? If so, that is a reversal of what you have been claiming for the better part of a decade.
Yes, for the purposes of this argument I will agree with that since we know that such a machine is impossible to build and it is not the scenario I am interested in discussing. So, can we forget the perfect stick figure and stick with the real world
In Reply To:
2) The data you posted demonstrates that you are still confusing physics with physiology. Until you understand the former you can't understand the latter, so let's stick with it for now (as Tom A. already suggested).
I am? Perhaps you could enlighten me as to where I am confused. Is there a difference between physics watts and "metabolic" watts? Exactly what is that difference.
In Reply To:
3) You should ignore the metabolic costs of unloaded pedaling. Again as already discussed in this thread, the fact that there is no external load means that we use our muscles differently than when there is one, making it an "apples-to-oranges" comparision. This is why A) the cost of unloadded pedaling is significantly greater than the y-intercept of the VO2-power relationship, and B) delta efficiency is considered the best measure of muscle efficiency.
McDaniel's data has a couple of things in it that are bothering me. Perhaps you could help me to better understand. Papadapalous, Tom, you, and about everyone else on the other side of this argument agree that there are losses associated with unloaded pedaling but as soon as the chain is loaded those losses will disappear because they can now be transferred to the wheel. While MdDaniel's data doesn't address this directly why is it that I suspect that when they are pedaling the 195mm cranks at 100 rpm (something almost everyone can do unloaded) and needing 290 metabolic watts to do this trick, I suspect that each and everyone of them will have difficulty sustaining 290 watts at the wheel for any length of time as soon as the chain is loaded. And, if it is true that all this energy is transferred to the wheel as soon as the chain is loaded, how on earth could they ever ride at anything less than 290 watts when pedaling at 100 rpm on 195 mm cranks? I am sure they can but how do they do it? Any ideas?
Oh, and I find the delta efficiency numbers interesting. The delta (muscle) efficiency is still increasing, even at 100 rpm. Where would you think this puts them on the contractile efficiency with shortening velocity part of the curve? The delta efficiency numbers obtained are substantially higher than I have ever seen documented for a loaded cyclist, they are even higher than those recorded by Coyle in Lance. How do you explain this?
In Reply To:
4) Re. your last sentence in your post immediately preceeding this one: you don't need to measure/calculate the cost of unloaded pedaling or delta efficiency to determine the most efficient (not optimal) cadence. The latter is simply the cadence that results in the highest gross efficiency at a particular power; measurements/calculation in addition to/beyond gross efficiency are only necessary when attempting to determine mechanisms.
To which post are you referring. I presume the one in which I asked if one could predict from fig 4 where the optimum pedal speed would be? I simply asked if you thought you could. I guess your answer is "no" since you dodged the question by saying you don't have to, all you have to do is test it directly.
In Reply To:
5) You've confused other issues/made other incorrect statements in these two most recent posts, but
I don't have time to correct them all at the moment, and attempting to do so would only confuse you further.
I guess you don't have time to even list them as to what they are, just leave the impression that . . .
Anyhow, you are probably right, your "corrections" would only confuse me more. (Actually, it is rare that you ever "correct" anyone, mostly what you do is simply pronounce them wrong then go away.) As I stated above, I am really confused as to how any of those riders would ever be able to ride at a light power when there is 290 watts of power in the legs just waiting to be automatically transferred to the chain and wheel as soon as it can be loaded, in view of what I have been told to be the truth earlier in this thread, and others. Again, help me here. I am trying to get as smart as you. I know it will be hard, but I am trying.
Frank,
An original Ironman and the Inventor of PowerCranks
