I am considering buying a 2014 tri bike (specialized shiv, cervelo p5, etc.) to replace a 2007 cervelo p3 carbon. other than the fun i will have building the new bike, what are the benefits i can expect for IM races?
Re: benefits of newer tri specific bikes [bcendrars456]
New frames are quite high cost, low return items. Therefore, in my opinion, the benefits will be less tangible i.e. motivational boost from new bike, etc... which could well translate into faster times. For the same cost, there is lower hanging fruit to be plucked.
That's not to say it isn't a good way forward; hey, everyone loves a new bike.
Re: benefits of newer tri specific bikes [JerseyBigfoot]
I asked the question a while ago about the difference between an old P2C to a P5 - general consensus is about 4-6 minutes over an Ironman
Re: benefits of newer tri specific bikes [nickag]
BTW the old P3 is long and low and the Shiv and P5 are short and high. If you want to run a low position alot of the older designs are better and body position trumps the bike if you are suitable for a low position.
bcendrars456 wrote:
I am considering buying a 2014 tri bike (specialized shiv, cervelo p5, etc.) to replace a 2007 cervelo p3 carbon. other than the fun i will have building the new bike, what are the benefits i can expect for IM races?you go a little faster
if you use a bento box you can bolt it on which is a little cleaner
that is it!
But the ill-positioning of a water bottle, wrong helmet, or a race number flapping in the wind will put you back where you were! :)
Steve Fleck @stevefleck | Blog
Re: benefits of newer tri specific bikes [Fleck]
Fleck, would a P5 cause your number to flap more than a P3 would?
One benefit of the P5 is the trucated downtube makes the penalty of a standard downtube bottle less than the old p3
Fleck wrote:
I asked the question a while ago about the difference between an old P2C to a P5 - general consensus is about 4-6 minutes over an Ironman But the ill-positioning of a water bottle, wrong helmet, or a race number flapping in the wind will put you back where you were! :)
nickag wrote:
I asked the question a while ago about the difference between an old P2C to a P5 - general consensus is about 4-6 minutes over an IronmanThat seems optimistic assuming your position stays the same, accessories, wheels/tires, etc. Just the frame itself, maybe 2-3 minutes at most, unless your a 6 hour rider.
TrainingBible Coaching
http://www.trainingbible.com
Re: benefits of newer tri specific bikes [jackmott]
Jack,
Come on. You know that when you stand on the side of the road in an Ironman on the bike leg, you see a direct correlation between how aero/expensive the frame is, and all the other aero-stuff the athlete is doing wrong! :)
Jack,
bcendrars456 wrote:
I am considering buying a 2014 tri bike (specialized shiv, cervelo p5, etc.) to replace a 2007 cervelo p3 carbon. other than the fun i will have building the new bike, what are the benefits i can expect for IM races?Position is King! Some of the new bikes with an integrated cockpit aren't as easy to fit correctly. A clean 2-piece bar and stem combo on your P3 might still be faster.
That said, there are probably a few minutes to be saved on a new frame. The new Felt IA, or maybe a Falco beam bike, would be my top picks, especially for IM distance. The non-UCI compliant design is pretty appealing at higher yaw angles. Felt calls their B2 a "parachute" compared to the IA!
grumpier.mike wrote:
or maybe a Falco beam bike, would be my top picks, especially for IM distance. The non-UCI compliant design is pretty appealing at higher yaw angles. Felt calls their B2 a "parachute" compared to the IA!I'd like to see some wind tunnel on that Falco first.
