Hi guys!
A bit of a tricky question. I run the Pro Missile Evo TT bars and they are awesome! The only thing is that I just got a fit done and not to my surprise, as I've noticed it for a while and the fit confirmed, my pads are a bit too close together and my fitter told me I need to space both out by about 1-2mm.
For those of you who run them or know about them. I currently have them screwed into the narrowest set on the actual bar and then the wider option on the actual pad holder. We tried to reverse the setup and put them on the wider set on the bar and narrower on the pad, but that didn't work.
He suggested the Zipp pad width extender (http://www.zipp.com/...16twepqvhr1ncitoalog) , but I called Zipp and they said it wouldn't be compatible with these bars. My fitter then said that I could probably make a custom extension pad like Zipp's, but I'm not sure how, what material, or where to even begin.
I would like to avoid going through another bar setup as I like this one and I don't want to have find another set and sell this one. However, I'm open to all suggestions!
Thanks!
Thanks!
