In Reply To:
In Reply To:
In Reply To:
hi tom,
what mass, rho and percentage of raw roller Crr did you use for the plot? Definitely the very best way to look at it for one's personal case!
I used Damon's 100 lb load and 1.5x "road roughness" factor to back out the aero drag at 30 mph. Rather than assuming a rho and solving for CxA, I just scaled the aero drag as the ratio of the apparent wind velocity squared over 30 mph squared (i.e. (Vw^2)/(30^2) )
But, once the "aero drag" is solved for, you can then modify the Crr drag for your particular wheel loading and "road roughness" assumptions and see how that affect things.
okay. For me that'd be ~250 lbs load ;-) which would change the intersection points or possibly remove some.
the 1/2*rho*CdA bit makes sense ...
Just for "giggles", I added 2 more "speculative" entries. The first is for a used VF record and the assumption is that it's aerodynamic performance will be the same as, or very close to, the Zipp and Bonty 21C tires. The second is for the same tire, but if it could somehow have the "wings" of the Aero TT added (with, perhaps, a bead of RTV?) and thus the same aerodynamic performance of the Aero TT tire. Again, this is for the 100 lb tire load case that Damon originally assumed.
It appears that the VF would perform nearly identically to the RXL Pro 23C tire, which isn't surprising since they have nearly identical Crrs and the aero drags appear to be similar as well. The performance of the VF, if it could get the aero drag of the Aero TT tire, is potentially outstanding. At 27mph, you're talking about a potential difference of ~70g of total drag force. That's equivalent to a time gain of ~.75s/km...or, ~30s over a 40K.
Enjoy.
