A friend took his Zipp 404's to the LBS to replace a spoke. They drove a screwdriver through the carbon fairing. Can this be repaired? Is the wheel safe to ride as is?
Re: Zipp 404 Repair [Pett'rifier]
Its not a fairing its structural. Looks like they are buying him a new rim I would say no its not ok to ride.
2019 T-Rex Tri Series
Re: Zipp 404 Repair [mknight84]
My thoughts but thought I would check with the experts. Thanks
What I don't understand is whey they are using a screwdriver to replace a spoke....am I missing something here?
If I was replacing a spoke on one of my wheels a screwdriver is not a tool I'd need to get the job done.
Re: Zipp 404 Repair [loxx0050]
No one said it was used in the repair of the wheel. Sometimes tools fall or get dropped, and sometimes it's on top of expensive stuff. I had a screw driver fall off a tool holder directly above my bike. It gouged the top tube so bad that it almost put a hole in it.
Re: Zipp 404 Repair [rijndael]
rijndael wrote:
No one said it was used in the repair of the wheel. Sometimes tools fall or get dropped, and sometimes it's on top of expensive stuff. I had a screw driver fall off a tool holder directly above my bike. It gouged the top tube so bad that it almost put a hole in it.Your point does make sense but the OP stated "they drove a screwdriver through the carbon fairing" which would lead one to believe they use a screwdriver while working on it. Now, if he said accidental impact or dropped something they I can agree with your statement. You may be right but it doesn't add up in my mind.
Tell the shop to get a new rim.
