I am looking for a more aero wheel for my tri bike, which is built on a Kestrel 4000SL frame from 2012. The problem that I have encountered is that the frame just doesn't allow for a particularly wide rim width. I have a Flo 90 that I can't use because, while has clearance when the tire is not inflated, the slight change in profile of the fairing that occurs when I am inflated to 100+ PSI causes the fairing to rub on the frame. I am running a Flo in front with no issues.
So, I need to look at solutions that are more narrow. I've found a few options, but other than pricing, I am having a difficult time determining the pros and cons of them.
The older Williams System 85 wheels were based on a 21mm rim width, so they will fit fine.
The Profile Design Altair 80 also has a 21mm rim width, and will fit without an issue.
Another option may be a HED H3, though I understand that it's rim width may be so narrow that it interferes with my tire choices (I run a 23mm GP IIS on my training wheels currently).
Most of the options that I have found appear to be based on a rim width that, especially with a toroidal fairing shape, may not fit my frame.
Does anyone have any insight regarding my options?
