Freehub moves along the hub axis (in and out) about 1.5-2mm. Is this normal? I googled but couldn't find an answer. Got 4 wheelsets in the garage and none of them have any freehub play let alone 2 mm.
Did they design this so the skewer is holding everything in place? Or are bearings on this hub shot?
There doesn't seem to be a way to tighten the freehub body on 177. (I'm used to wheels that can). Apparently pull the end caps and you can just pull the freehub body out with your fingers. There is no clinch nut like on 188.
Asking because this is a new build and the rear shifting is atrocious. Shifting problems up and down, or can adjust half the cassette to shift okay but then the other half is grinding. RD hanger is brand new and so are cables. I thought it might be loose freehub and looks like it is....
