Just to add to the general knowledge on things that interfere, I was at wits end trying to figure out why my wifi range had dropped considerably in the past several months. Just suddenly, no wifi signal in the garage, which was several walls and 80 feet away from base. After doing some research, found out that led light bulbs can interfere with signals. Switch those out of the garage, back to incandescent and voila, range improved.
Led light buoys were also affecting the range of the garage door transmitter. Weird thing was that even off, the led light bulbs seem to interfere. Had to unscrew them and remove completely to restore signal range.
Hope that helps.
mongooseman wrote:
boyle_supremacy wrote:
I had to force my router settings to a channel between 1-6 for the 2.4ghz frequency. If I leave it to auto, it usually defaults to 11 and interferes with my ANT+ duotrap/garmin 920xt. It causes my speed and cadence to constantly drop for several seconds at a time. Over the course of a 60 min ride, I would routinely lose 6 minutes worth of data. After some researching, I found that ANT+ uses the same spectrum as channels 7-11. If you have 5ghz this will never be an issue as I believe it uses a much higher spectrum, however, the downside to the 5ghz is that it doesn't have the same range as the 2.4gz.
Thanks - that's just explained why my SC Duotrap drops out so frequently in the house. I'll get my router sorted out later today.
