MAIN INDEX RULES & LEGEND LOG IN
Slowtwitch Forums: Triathlon Forum:
Where do you mount your race number? Pictures please
AMT04
Jun 9, 12 8:50
Post #1 of 13 (1218 views)
Where do you mount your race number? Pictures please Quote | Reply
So I did a search on this, but nothing popped up in the first 30 pages of results.
Where do you mount your race number on your frame? Our local races usually provide large numbers that, even trimmed, are difficult to mount without having it flapping in the wind. I'd love to see some pictures of how most of you solve this and your rationale for doing so. Thanks.
-Andrew
Peanut
Jun 9, 12 9:19
Post #2 of 13 (1165 views)
Re: Where do you mount your race number? Pictures please [AMT04] [In reply to] Quote | Reply
At least for U.S. triathlons, I don't think it has to be in any particular place, as long as it's visible. I've seen them on:
- top tubes
- down tubes
- seat tubes
- seat stays
- seat posts
- aero bars
- extending straight back off of a hangar attached to the seat tube
I think as long as it meets the following, it will suffice:
- not interfering with anything mechanically
- not brushing against your arms or legs, for the annoyance factor
- try to have it visible from both sides of the bicycle, but if it can only be from one side, make sure it's the left side (that's the side the officials ride up on)
- the number should be readable horizontally, or at most vertically up-down or down-up. Don't put it on upside-down on the down tube
Look at some other bikes at your next race for ideas. You might also check the bike photos for a recent race, especially if the photographer is taking side or angle shots.
GMAN19030
Jun 9, 12 9:22
Post #3 of 13 (1159 views)
I put mine on the seat post. The Trek SC seat post is quite wide so they normally fit well with a little bit of scissor work to the sticker.
bullshark
Jun 9, 12 11:13
Post #4 of 13 (1044 views)
Seatpost on my P3 and I use a stapler to secure it nice and tight.
AnthonyS
Jun 9, 12 11:22
Post #5 of 13 (1023 views)
If I were taller, I'd go the seatpost route. Since I'm not, I have a zip tie or cable housing stuck into the seat clamp hanging out the back. I attach the big numbers to it.
I really do like the smaller numbers that come with the Tri tats. I'm not convinced I like the tats but their bike and helmet numbers are very nice.
You will remain the same person, before, during and after the race. So the result, no matter how important, will not define you. The journey is what matters. ~ Chrissie W.
TriDevilDog
Jun 9, 12 12:13
Post #6 of 13 (967 views)
Most races use stickers, and I trim them to precisely the size of the number and stick them to my seat tube.
The seat tube on my Scott Plasma is aero, but hardly remarkable and has always had enough room for the ~2" high numbers.
I ride a 52cm frame and still have plenty of room - I rotate the sticker 90' so the 'bottom' faces my rear wheel.
If you still get the cardboard numbers with twisties, I prefer the front of the top tube (wrap it over the tube and underneath where the
bento box would be). Again, trim for a tidy fit and wrap the twisites around the down tube. Use tape to secure
in place and minimize any gaps.
" I take my gear out of my car and put my bike together. Tourists and locals are watching from sidewalk cafes. Non-racers. The emptiness of of their lives shocks me. "
(opening lines from Tim Krabbe's The Rider , 1978
AMT04
Jun 9, 12 12:56
Post #7 of 13 (907 views)
Re: Where do you mount your race number? Pictures please [TriDevilDog] [In reply to] Quote | Reply
Not around here. We get these huge paper numbers with 2 small strips of adhesive on the back. Its the I've been doing it the same way for a few years now and I keep thinking there has to be a better way. This picture is from last year, but you can see how much space it takes up even on my relatively long seat tube. Granted, there's a lot of room to trim there, but not without cutting out all the adhesive on the back.
At the larger races I've done, the stickers or hard plastic numbers haven't been a problem. For the local sprints and olymipcs I'm just tired of having my number flapping around like a sail.
-Andrew
littlefoot
Jun 9, 12 13:04
Post #8 of 13 (889 views)
I always took scissors and tape to a race. Id cut the number to fit my seatpost and tape it on. I didnt worry about the adhesive because the tape solved it.
TriDevilDog
Jun 9, 12 13:04
Post #9 of 13 (888 views)
Re: Where do you mount your race number? Pictures please [littlefoot] [In reply to] Quote | Reply
zactly...
RandyS
Jun 9, 12 13:13
Post #10 of 13 (870 views)
Sorry but I don't have a picture but I trim the number to fit on my down tube. If it is not a sticker, I attach it with clear packaging tape. The numbers are usually a bit too high to fit without trimming so I cut off a bit of the top and a bit of the bottom to make it fit. I tape the leading & trailing edge (if done right, I don't need to tape the bottom but I don't think it would hurt). Most races say not to alter the number but I have never been given any trouble (m-dot, non-mdot, US, Europe, whatever). Be sure to have a napkin or dry cloth to wipe off the morning dew from the frame so the tape will stick. If you don't have an aero downtube, I suggest going with the seat post placement.
coltank17
Jun 9, 12 13:13
Post #11 of 13 (870 views)
Trim it down, and use a stapler. Staple it close to the seat tube, and then at the end.
____________________________________________________
"I like you. I'll gladly sit down and have dinner with you after the race. But when the gun goes off, I pretty much hate you, and I want to stomp your guts out. That's racing." -Rappstar
http://train4autism.org/
Hydro
Jun 9, 12 13:31
Post #12 of 13 (841 views)
trim to minimum possible size, wrap around seat post as high as possible, tape side of number together with clear packing tape, and secure the whole thing to seat post with electrical tape (peels off cleanly).
Pic of setup from this morning's race:
Cheers, Chris
"You were sick, but now you're well again, and there's work to do" - Kilgore Trout
jen-g
Jun 9, 12 17:27
Post #13 of 13 (662 views)
I cut the numbers out, trim them down and then clear tape it to the frame on the down tube where its thickest near my water bottle cage. I would upload a picture but can't seem to do it on here.
Twitter: @jayasports
Web: http://www.jayasports.com
The New Specialized Wind Tunnel
Will this be a game changer for Specialized, in both sales and product design, or will it not move the sales and design needle versus those in Specialized's competitive set?
Yes, Game Changer
Minor move forward
Won't budge the needle
