bmas wrote:
After reading about the typically strong trade winds expected on the Kona bike course, and the fact that disk wheels are not permitted for that reason, I'm thinking I should leave my Flo 60/90 race wheels at home and just use my normal road bike wheels instead. I figure that the time lost due to worry of crosswind gusts will probably exceed the benefits gained by race wheels.
Anyone else leaving their race wheels at home?
I'd ride the race wheels if I were you. I rode the course on a FLO 60 set which is slightly less stable than a 60/90 set and didn't really have that many issues on the course. I'm 5'11" and 155lbs for reference. The only place that was a bit "white-knuckle-ish" was the decent from Hawi, but if there is a rider in front of you, you see them being hit by the wind blowing between the openings in the rock and know when to expect it. If you are overly worried about it, you may want to consider an aero wheel in the 30-45mm depth range on the front of your bike to help.
I'm not sure what your goals are in Kona, but if you are competing, giving up your race wheels will cost you. If you simply want to finish and have a great time without worrying what the clock says at the end of the day, ride any wheels you want.
I hope that helps,
Chris Thornham
Co-Founder And Previous Owner Of FLO Cycling
