MAIN INDEX RULES & LEGEND LOG IN
Slowtwitch Forums: Triathlon Forum:
What's the "virtual" CdA and Crr of the LeMond Revolution?
First page Previous page 1 2 Next page Last page  View All
Tom A.
Jan 28, 11 15:51
Post #1 of 30 (3078 views)
What's the "virtual" CdA and Crr of the LeMond Revolution? Quote | Reply
That's a question I've been interested in quite awhile...and with my getting access to one recently, I decided to run a few tests/analyses.
Just in case anyone besides me was interested, here's the result of a constant cadence cassette sweep (only 9 of the 10 cogs of a 12-25 cassette, 60 rpms, with a repeat of the 53-14 at 75 rpm for some slightly higher power.) After the sweep, I did some accelerations/decelerations for the purposes of doing some inertial mass estimates (more on that later).
Taking the average of the power and "virtual speed" (i.e. the result of the gearing, cadence, and assumed wheel rollout) over the last 2 minutes of each step (and the last 1 minute of the 75 rpm step), I then plotted P/V vs. V^2 for the following:
Assuming an "all-up" mass of 85kg, and a rho of 1.2 kg/m^3, that y-intercept works out to represent a Crr = .0051 and the slope of the line works out to represent a CdA = .350 m^2. Sounds like a fairly "normal" road bike position (on the hoods) and Crr.
Now...about that estimate of inertial mass. My intent was to plug the file and the calculated Crr and CdA into my VE spreadsheet and then modify the mass entry until the small "hills" formed by the accelerations/decelerations "flatten out"...I tried that, but I think I need to reconsider how varying the mass entry affects the calculated rolling resistance force (I might need to separate out the mass terms used for the rolling resistance calcs and the other places the mass term is used). Although, with an assumed 85kg mass, it's pretty darned flat as it is. (I actually had to slightly increase the CdA to .353 to flatten out the "steps")
I think I might just pull the fan/flywheel cover off and measure up the flywheel and just manually calculated the moment of inertia ;)
(This post was edited by Tom A. on Jan 28, 11 16:04)
RChung
Jan 28, 11 16:10
Post #2 of 30 (3062 views)
Re: What's the "virtual" CdA and Crr of the LeMond Revolution? [Tom A.] [In reply to] Quote | Reply
Tom A. wrote:
What happens if you accelerate more gently and then coast down (e.g., make the speed trace look like a triangle)?
Tom A.
Jan 28, 11 16:22
Post #3 of 30 (3046 views)
Re: What's the "virtual" CdA and Crr of the LeMond Revolution? [RChung] [In reply to] Quote | Reply
RChung wrote:
Here's what the speed trace looks like from the accel/decel section...I guess I accelerated faster than I'd thought. My intent was to give it a big "signal"...but yeah, maybe I need to be a bit more gentle...
RChung
Jan 28, 11 17:04
Post #4 of 30 (3022 views)
Can you overlay the VE on that speed trace?
bazilbrush
Jan 28, 11 17:22
Post #5 of 30 (3006 views)
Is this thread available in English?
JustinPB
Jan 28, 11 17:49
Post #6 of 30 (2990 views)
awesome. I love this stuff. I've been playing with this with my KK since I got a powermeter. I'm going to have to "Chung" myself once i get a free saturday.
Tom A.
Jan 28, 11 17:58
Post #7 of 30 (2981 views)
Like this?
Tom A.
Jan 28, 11 18:10
Post #8 of 30 (2970 views)
Re: What's the "virtual" CdA and Crr of the LeMond Revolution? [bazilbrush] [In reply to] Quote | Reply
Sure...quick translation...I wanted to quantify just how close the Revolution "mimics" riding outside and this thread is showing how I'm doing that. So far, the "load curve" of the Revolution appears to match VERY well the "typical" aero drag and rolling resistance of riding your road bike outside on perfectly level ground. I was able to determine this using the same method one would use to field test to determine aero drag and rolling resistance outside using a power meter.
The last piece of the puzzle is determining how well the flywheel "mimics" the inertial mass of a rider+bike traveling down the road at the same indicated speed. I tried doing that using Robert's VE technique and the coefficients measured above. That's what Robert and I are going back and forth about...
Up to speed? ;-)
RChung
Jan 28, 11 20:42
Post #9 of 30 (2931 views)
Tom A. wrote:
Aha. Excellent. It may "coast" better than regular trainers -- but not as well as a bike on a flat road. Likewise, it appears to accelerate faster than a bike on a real road. Steady state load is reasonable, though.
RChung
Jan 29, 11 7:09
Post #10 of 30 (2864 views)
RChung wrote:
I presume you were using an all-up mass of around 80kg? So cut that in half to 40kg and double the Crr to .01. That'll keep the steady state power the same but should improve the modeling for the KE component.
uberslug
Jan 29, 11 12:53
Post #11 of 30 (2785 views)
Doesn't anyone just ride their bike anymore?
I know enough to know I don't know enough...
JustinPB
Jan 29, 11 12:54
Post #12 of 30 (2784 views)
Re: What's the "virtual" CdA and Crr of the LeMond Revolution? [uberslug] [In reply to] Quote | Reply
why do you have to be an ass?
uberslug
Jan 29, 11 16:35
Post #13 of 30 (2732 views)
Re: What's the "virtual" CdA and Crr of the LeMond Revolution? [jpb] [In reply to] Quote | Reply
I believe it was Lao Tzu who wrote "To become learned, each day add something. To become enlightened, each day drop something." So, in that vein, I am considering moving past the gaining of knowledge through the use of power meters and embracing a more zen like approach to training.
In looking back at my wording, I can see where my question could be misinterpreted. Mea maxima culpa...
Tom A.
Jan 29, 11 17:24
Post #14 of 30 (2720 views)
Yeah...I thought of the same thing last night. Just modify the Crr to compensate for changing the mass so that the rolling resistance force stays constant. I just haven't had a chance yet to try that....
Sausagetail
Jan 29, 11 18:16
Post #15 of 30 (2709 views)
I thought this was the most interesting thread in the past week or two...
RChung
Jan 29, 11 19:19
Post #16 of 30 (2694 views)
Re: What's the "virtual" CdA and Crr of the LeMond Revolution? [Sausagetail] [In reply to] Quote | Reply
Lemond is selling their "Power Pilot" for, what, $400+? With Tom's info, you can print out the cadence-gear-power combos on an 8-1/2" x 11" sheet of paper and scotch tape it to the wall. Send 10% of the savings to Tom.
Tom A.
Jan 29, 11 20:07
Post #17 of 30 (2677 views)
...except that doesn't provide one with a downloadable record of the session ;-)
RChung
Jan 29, 11 21:20
Post #18 of 30 (2656 views)
Work with me.
VO2Matt
Jan 30, 11 9:58
Post #19 of 30 (2597 views)
So use a computer that logs cadence and rear wheel speed. It's simple spreadsheet math from there.
sometimes you just have to eat the cake
Tom A.
Jan 31, 11 14:56
Post #20 of 30 (2447 views)
RChung wrote:
Here's the "best fit" I could find...and I mostly judged it off of the final "tail" which was a coast down to zero rpm. I adjusted the mass (and Crr accordingly) until the final steady-state leg and the coast down to zero had a minimum of "disjoint". This case was actually 100 lbs (45.5 kg) and a Crr of .0094
Now...we'll see how close that is to a calculated mass based on the flywheel geometry!
atopham
Feb 7, 11 5:51
Post #21 of 30 (2321 views)
So I'd love to be able to evaluate all this myself but my head starts to hurt when I try. I have a Kurt Kinetic right now and it is an awesome piece of kit, with a very long coast down from, say 20 mph, of over a minute. But that vstill leaves me pushing 15% less power through it than I can on the road in the TT position. So can you tell me what the coastdown time would be from 20 mph on the Lemond?
Cheers.
http://www.timetrialling.com
TT is like stubbing your toe very hard. It's self inflicted, it's stupid and it REALLY hurts!!
Tom A.
Feb 11, 11 20:12
Post #22 of 30 (2235 views)
Had a chance today to pull the flywheel cover off and measure up the flywheel on the trainer. Decided to just throw the dimensions into Pro/E and let it do the moment of inertia calculations:
Here's the mass properties output:
Quote:
VOLUME = 8.0428750e-04 M^3
SURFACE AREA = 2.0893183e-01 M^2
DENSITY = 7.8887728e+03 KILOGRAM / M^3
MASS = 6.3448414e+00 KILOGRAM
CENTER OF GRAVITY with respect to _GL_FLYWHEEL coordinate frame:
X Y Z 0.0000000e+00 0.0000000e+00 2.4937030e-02 M
INERTIA with respect to _GL_FLYWHEEL coordinate frame: (KILOGRAM * M^2)
INERTIA TENSOR:
Ixx Ixy Ixz 4.2069766e-02 0.0000000e+00 0.0000000e+00
Iyx Iyy Iyz 0.0000000e+00 4.2069765e-02 0.0000000e+00
Izx Izy Izz 0.0000000e+00 0.0000000e+00 7.3130437e-02
INERTIA at CENTER OF GRAVITY with respect to _GL_FLYWHEEL coordinate frame: (KILOGRAM * M^2)
INERTIA TENSOR:
Ixx Ixy Ixz 3.8124192e-02 0.0000000e+00 0.0000000e+00
Iyx Iyy Iyz 0.0000000e+00 3.8124191e-02 0.0000000e+00
PRINCIPAL MOMENTS OF INERTIA: (KILOGRAM * M^2)
I1 I2 I3 3.8124191e-02 3.8124192e-02 7.3130437e-02
ROTATION MATRIX from _GL_FLYWHEEL orientation to PRINCIPAL AXES:
1.00000 0.00000 0.00000
0.00000 1.00000 0.00000
0.00000 0.00000 1.00000
ROTATION ANGLES from _GL_FLYWHEEL orientation to PRINCIPAL AXES (degrees):
angles about x y z 0.000 0.000 0.000
RADII OF GYRATION with respect to PRINCIPAL AXES:
R1 R2 R3 7.7515746e-02 7.7515748e-02 1.0735906e-01 M
The value we're interested in is the the Izz value of .073 kg*m^2.
So...how do we equate this to an "equivalent mass" translating down the road? I like to do it by equating the kinetic energy of the flywheel to the kinetic energy of a bike+rider moving down the road.
Kinetic Energy of rider = Kinetic Energy of the Flywheel
KErider = KEf
1/2 x mass of rider x (velocity of bike)^2 = 1/2 x Izz x (flywheel rotational speed)^2
Mr x Vb^2 = Izz x (Wf)^2
OK...to solve this, I need to equate the flywheel rotational speed (in radians per second) to the equivalent bike velocity (in meters/second). Well, the assumption above was that the wheel rollout was 2080mm, or 1 revolution = 2*Pi radians is equivalent to 2080mm of rollout.
Wheel rotation rate = Ww = Vb x (2*Pi radians/2.080m), where Vb is in m/s, so Ww = 3.0208 x Vb.
Now, to figure the flywheel rotational rate, we need to know the pulley ratio of the drive pulley and the flywheel pulley. By my measuring, this ratio is 8:1. So, the flywheel rotational rate, Wf = 8 x Ww = 8 x 3.0208 x Vb = 24.166 x Vb.
Lastly, I'll plug this relation into the simplified KE equation above along with the calculated Izz from the solid model.
Mr x Vb^2 = Izz x (24.166 x Vb)^2
Mr = Izz x 584 = .073 x 584 = 42.6 kg
42.6 kg is equivalent to a rider weight of ~94 lbs...now, that's also not including the other rotating bits (like the pulleys, cassette, etc.)...but that's pretty darned close to the "equivalent mass" determined using the coastdown and VE above :-D
bpq
Feb 11, 11 20:22
Post #23 of 30 (2224 views)
Nice. I've gone to the dark side and now work for sales. I miss Pro-E.
RChung
Feb 11, 11 20:27
Post #24 of 30 (2220 views)
Tom A.
Feb 11, 11 20:28
Post #25 of 30 (2218 views)
RChung wrote:
Hehehe...I actually was going to put that at the end of the post, but forgot. Thanks!
The Strongest Cyclists in Triathlon
On average, which group of pro triathletes would fair best in a 3-day stage race, consisting of a hilly road race, crit and 20k TT?
ITU-style triathletes
70.3 and Ironman triathletes
