I'm not having much luck with latex inner tubes. Attached is a picture of the hole in the tube from this weekend's flat.
New tube (Michelin). New tire (GP4000S). I use 2 layers of Stan's tape.
Plenty of talcum powder. And I'm able to install everything without using tools.
I blew enough air into the tube to give it some shape. After getting the tire on, I checked all the way around to make sure nothing was pinched. I inflated to about 40 psi to make sure the tire seated well. The next morning I inflated to about 100 psi before my ride.
The flat happened about 10 miles into the ride. I've never see a hole like this. It was on the side of the tube, not under the tire tread, or at a spoke hole.
I double checked the rim tape and it was still well positioned over the spoke holes.
Any ideas?
Thanks,
Scott
Any ideas?
Thanks,
Scott
