PushThePace wrote:
I think as long as you keep it from becoming dry there isn't much loss at all. The losses come more so with the nicks in the neoprene. So as long as you don't through it in a closet 3/4 of the year and are always keeping some water in the neoprene you'll be fine. I make sure that I soak mine at least once a month for 10 minutes in the bathtub during the off season to ensure some moisture stays trapped. They are like big sponges with a rubber coating in the end. If you don't or haven't been doing that then you may want to start.
I am fascinated by this idea that closed-cell rubber is supposedly like an open-celled sponge, i.e. soaks up water like a sponge. Do you find that your suit has lost some of its flotation by the end of an hour or two swim as the neoprene has somehow soaked up water? That sounds slow, even dangerous, no? I am assuming it's the structure of the neoprene, i.e. nitrogen-blown rubber, that you think absorbs water, not the rubber itself (note that sponges are both open-celled and made of materials that themselves absorb water), i.e. you don't rinse down your rubber car tires regularly to keep them hydrated and not cracking, right?
I am obviously deeply skeptical of the notion that neoprene absorbs any water at all, or that it's desirable to try to keep it wet. But lots of people on this forum, to include a significant wetsuit manufacturer, seem to agree with you, so I'm genuinely curious to try to understand what, exactly, people think is going on here.
