kblahetka wrote:
So on a shorter ride I aim to keep my watts above 300 and by nature my cadence floats between 95 to 105.
When I dial it down for longer rides to stay in the 250 to 300 range my cadence drops to around 90 to 95? Is this pretty normal?
Look at the plot above with cadence on the x-axis and crank torque on the y-axis. Imagine a region around 95-105 rpm with watts above 300, then imagine a region around 90-95 with watts between 250 and 300. What is your cadence (for the same terrain) when your power is in the 200 - 250 range? For many people, it will be a little lower still. For the same terrain, when you increase power you generally increase both cadence and crank torque -- you don't just hold cadence constant and move vertically up to higher crank torque. The amount that you increase cadence and crank torque (for the same terrain) turns out to be individual. Some people increase their crank torque more and their cadence less, some people increase their cadence more and their crank torque less -- but almost everyone increases both a little rather than holding one of them constant. The particular pattern you have for a particular terrain determines the power expansion path.
Things are a little different when you're climbing vs. on the flat. Power expansion paths differ for climbs and flats, which is why I've been specifying "the same terrain."
