To add the speed sensor to the Kickr, I used a Garmin GSC 10 sensor that I wasn't using and attached it as shown in these photos:
https://www.facebook.com/...e=1&l=b015e7cf87 I had also experimented with using the new-style magnetless Garmin sensors, but I couldn't get it to work consistently. Also, the only place it would fit was inside the upper belt assembly and even then there was a bulge when I reinstall the pastic cover.
The trick with adding the speed sensor, I found, was to find something that would work given the tight spaces on the Kickr. There isn't a lot of room to add a magnet that won't hit or rub. That's why I thought the magnetless sensor might be a good choice, but to no avail.
I also experiemented with adding the magnetless senor to the heavy flywheel. I estimated that this travels at 8x the speed of the casette/upper belt wheel, so I would adjust the speed sensor circumference value in the Garmin computer by dividing the normal number by eight. It kinda works, but it throws the balance of the flywheel off and the trainer becomes unusable. Also, the sensors have a hard time picking up a wheel moving that quickly.
So, once I determined that I was going to use the GSC 10, I had to determine the best place to mount the sensor and magnet. There may be better solutions, but I decided on the positions shown in the photos. The sensor position gives good visibility of the sensor and should allow me to change the battery without having to remove the zip ties.
To attach the magnet, I first disassembled the upper wheel assembly to see what was possible. Just sticking a magnet on the plate doesn't work as there is not enough clearance for the wheel to turn. This may be possible with very small, powerful magnets, but I didn't have anything small enough on-hand to try.
I determined I needed to drill a hole into the plastic cover of the upper wheel that a magnet could be placed into. If you look at the photo of the upper wheel with the plate removed you can see that the hole needs to go in one of the recessed areas.
I was able to fit a magnet very securely in a hole that was drilled. To help find the best location, I also drew a pencil mark by spinning the wheel with the pencil tip right at the notch on the sensor which is used to align the magnet.
Once everything was finished, I was getting 2x speed because the sensor was picking up the magnet twice as it passed by. The sensor isn't angled ideally with this setup (although it was the best solution I could find) which can cause this. I simply slid the sensor back a bit, though, until it only picked up the magnet once per revolution. (Pressing the button on the sensor until it turns red really helps when setting the magnets up. Once in this mode, the sensor light will flash green whenever it senses the magnet.)
