Hi guys.
So I've been back and forth trying to find a good position on my P3 for some time now and got a retul fit a couple of weeks back. Ended up changing the orginial 90 stem for a 60 stem but the retul fitter still says that the reach is a little bit long.. I did ask a similar question earlier and I got feedback that my posture is terrible and I'm not rotating my hips.. Others have said I should lower the cockpit which I also tried - it did feel quite good but my hips felt kinda squeezed, like I was unable to generate power. The first thing the retul fitter did was actually raising the 3T bar again.
I just can't understand what seems to be the issue.. Based on the info I got from the fitter I started wondering about changing cockpit or perhaps changing bike as I've read that Cervelo's can be quite long.. So, using my retul fit and checking other bikes I'm quite baffled.. I might be totally wrong here, but wouldn't my Pad Y & X be something like 441 and 689mm - and as I should have a even shorter reach (according to my fitter), close to no bikes fit? I've been looking into Scott Plasma, Cervelo P5 (54 size), Canyon Speedmax and so on.. I must be completely off here? I talked with canyon and they suggested a large frame which from the specifications provided looks like it has MORE reach than the P3.
Attached retul report and pic of my last race a couple of weeks ago with the retul fit position. I can do a better photo/video if it's no good.
Height: 184cm
Inseam: 84cm
Torso length: 58cm
Width: 40cm
Arm length: 62cm
Height: 184cm
Inseam: 84cm
Torso length: 58cm
Width: 40cm
Arm length: 62cm
