UPDATE -- tips for removing braze on fdr hanger
Well, that was easy. 15 minute job including removing residue and painting.
Drilled out rivits with 1/8" bit
Punched back, but couldn't punch all the way through
Heat gun
Pry off fdr hanger
used 3/8" bit to drill off remaining fat part of rivit
Punched into frame
Removed glue residue with goof off
Wiped with isopropol alcohol and let dry
Masked
Painted with black plasti-dip.
_________________________
I've got a 2015 venge that is used 95% as a crit bike.
Have been using 1x11 for 2 full seasons and don't see myself going back.
I've also crashed this frame about a dozen times (and it shows), so not too worried about losing value if/when I sell it.
I'm thinking of drilling out the rivits that hold the fdr hanger and using a heat gun to remove it from the frame. If I screw it up, will probably get cyclocarbon to fix it.
But wondering if anyone has tips for removing the fdr hanger from a carbon frame like this.
Thanks
Andy
Re: tips for removing braze on fdr hanger [AndyPeterson] [ In reply to ]
Re: tips for removing braze on fdr hanger [Morelock] [ In reply to ]
ooh, nice write up. Exactly what I was planning on doing.
Andy
good luck!
Hopefully "S" wasn't heavy handed with the glue.
My Blog - http://leegoocrap.blogspot.com
That's how it's done.
I was going to say don't do it, but on an old crashed frame? Sure go for it. Let us know how it goes.
Me , I would leave the base attached to the frame and just dremel off the bit that sticks up. That way it's mostly gone and I'd just have to paint a very small edge and not a pretty large area if you remove the base
It won't look as clean ( if you are good at painting ) but from 6 feet away I bet you wouldn't be able to tell the difference
Morelock wrote:
this is what i did
I am not sure I would use the heat gun if you don't have to. Heat can soften the epoxy that holds the carbon of the frame together.
I used one of the box cutter razor blades. I put the blade between the hanger and frame and tapped on the back of the blade to slowly work the blade between the two. I moved around the edge of the hanger until it popped off. This was on a Shiv.
Re: tips for removing braze on fdr hanger [Thomas Gerlach] [ In reply to ]
Yeah gen1 7 series.
As for the heat gun...meh, skip it if you want. Loosening some of the epoxy in that area (if it did) doesn't concern me, but ymmv of course, I'm sure you could get it off without the gun with enough work.
Just replying to you so you see update.
I did your technique and worked great.
Thanks again
Andy
Thanks again
Andy
Awesome! Great success!
