Tririg ergo cups on other base bars?
Can I run Tririg ergo cups/pads on a zipp Vuka aero for more adjustment options? Is there anything I'm missing here. Any reason why this wouldn't work?
Re: Tririg ergo cups on other base bars? [Fishbum] [ In reply to ]
I just got them with the intention of using them on a Felt base bar but the spacing of the bolt holes is different, so they don't work. I've been able to use Hed cups on a Felt bar and vice versa, so I think the Tririg spacing is different than industry standard.
Re: Tririg ergo cups on other base bars? [THesel] [ In reply to ]
There isn't an "industry standard" spacing for bolt holes. Some holes are vertical, others horizontal, and often at different spacing. So we publish the actual specs of our cups in the same spot you purchase them, so you can know beforehand what our spacing is, and measure to compare to your existing setup.
TriRig.com
