Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [Slowman] [ In reply to ]
All the current good bikes are good.
I'd like to see how my old P2K or 2013 P2 compare to the current bikes. but given that the test results mimic Cervelo's published data, I think I'll just believe the statements Cervelo have made over the years, about the drag of their bikes.
That said, to paraphrase Slowman from many years ago, "my P2 isn't what's keeping me off the podium"
TriDork
"Happiness is a myth. All you can hope for is to get laid once in a while, drunk once in a while and to eat chocolate every day"
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [BryanD] [ In reply to ]
BryanD wrote:
so disc brakes aren't as slow as we thought....
hrmmm I believe I said that a couple of times in the P5-X thread but no one believed me and wanted to run their mouth
+1
Like!
TriDork
Sorry if this has been asked before in the previous pages, but for the data graph, what is the SE for the data?
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [desert dude] [ In reply to ]
desert dude wrote:
On some/many of the older generation bikes some of that storage stuff can make the bike faster. There are 2 different bikes out there where we saw adding aero bottles to the frames saved a few watts. Now these are among the smaller/est sizes but even on my bike, which is a medium, running a round down tube bottle is neutral. We've confirmed this on 2 other riders on my same frame in the past. But on large size of my bike everyone has been slower with a frame bottle, significantly slower. Maybe this is a situation where storage designed into the frame would be beneficial.
Any thoughts or data for aero bottles on the frames of newer "Superbikes"? Specifically I'm thinking about Frodeno and Kienle (among others) racing with the Elite Crono on the down tube. They certainly have the means, time, and desire to sweat aero details so I'd be surprised if adding that bottle incurred an aero penalty. And Frodeno certainly isn't riding a small or medium SLX.
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [BMANX] [ In reply to ]
BMANX wrote:
I have been able to pick up parts here and there for cheap. TriRig Aerobars for $400, other parts pouched from other builds, 1x done stupid cheap as I don't buy into the hype of clutch and narrow/wide. Mods done for $25 to run cables more aero behind the stem. Modifying a build to be more aero does not have to cost thousands like others have mentioned. The next step of course is to get a PM to start to test position changes and then final would be tunnel time.
I think it is a little more difficult than you think. I tried to find a P4 and a set of 3t Ventus bars this year, but once you get down to specifics (e.g., a 54 cm P4 with the 2011 brakes so it actually kinda stops) the pickings have been slim to none on EBay. Issues like missing the aero bottle make it that much harder to cobble together a really fast combo.
As far as Chung testing and a PM. I am kinda there already. My setup is pretty dialed and the measurement error of small changes is hard to overcome.
What I find interesting is that people don't think 10 watts is that big a deal. 30-40 seconds over 40k is huge! I sure didn't find that much the last time I went to the WT.
Feels like Slowtwitch have doctored the summary to suit there alliance with Cervelo.
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [heman] [ In reply to ]
I don't think that is the case at all.
Dan did his write-up on the cover page but he was not involved in the testing or the report.
The report speaks for itself.
Dan Kennison
facebook: @triPremierBike
http://www.PremierBike.com
http://www.PositionOneSports.com
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [Rappstar] [ In reply to ]
Rappstar wrote:
Not really replying to you, Brian, but I think one of the big takeaways here is the basebar. I'd *guess* a big reason the Tactical does so well is that very slender base bar. Given what Tom A and others have posted about the drag from going "aero-or-die," the differences in base bar could be enough to substantially re-order some of these frames. Especially if you consider those frames that have a standard steerer tube and which could use a different bar/stem combo than what was tested.
Given my own bias, I certainly wonder how the Andean would do with a different bar setup, since I don't think the HED Corsair is particularly good.
It's interesting that we talk about this as a "frame" test, but really it's frame+bars, and bars make a big difference... How much faster, for example, would the Ventum be if they made a Tactical-esque base bar?
A good example of the effect of the base bar/levers is the testing of the P4. The P4 killed all the other SuperBikes when fitted with the Ventus. Specialized tested the nosecone Shiv against the P4 and showed that it was a bit faster, but it took a fugly looking Profile bar, sloppy cabling, and an inch or two of steer tube spacers.
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [grumpier.mike] [ In reply to ]
Upgrading brakes is an inexpensive way to pick up a watt here or 3-5w there.
Bars are more complicated bc now you are having to plot out fit coordinates, if you can separate elbow pads from the base bar, which extensions fit, cable routing and all that time consuming stuff.
When you get to the average triathlete who isn't necessarily trying to be at the FOFOP they shrug and think that it's a lot of hassle. They look at all that, and up to 10x more expensive than the brake and say ehhhh I'll get a bit of bang with the brakes and call it good.
Brian Stover USAT LII
Accelerate3 Coaching
Insta
Yeah, the Ventus was the one that really - I think - opened people's eyes to how fast a bar could be. And, I might add, how un-usable (at least for certain races). But man it was fast. The Tactical base bar reminds me a lot of the Ventus, just with normal brake hoods.
The fastest bars - the original Ventus and USE Tula - both made serious ergonomic sacrifices. But I still feel like they opened the door a bit in terms of showing what was possible.
Is a NP3/NP2 with USE Tula bars going to be pretty much superbike worthy?
Exactly. There was an elaborate setup where Slowman temporarily banned Pubes in part for over-the-top criticisms of bikes that included the P5X. . And then Slowman expressed that the results of this test would require "extreme vetting" before he'd allow it on the site.
This was all an elaborate misdirection and marketing ploy by Cervelo. Follow the money, man.
Please.
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [trail] [ In reply to ]
Hello Trail and All,
Holy Batman Trail! You are on to it .... Pubes secretly owns Pon Holdings and he is a marketing genius.
Who knew?
Cheers, Neal
+1 mph Faster
Just to be contrary I'll point out that the original vision Trimax one piece bars predated Ventus by at least 10 years and were much the same principle - you get a little bit of pad width adjustment and that's it.
Ventus added extension length adjustment and a much longer airfoil, took away anything to hold on to by the brakes and gained a little speed (according to the 2007 Cervelo data). In the order of 20s over a 70.3.
With current Zipp, Enve, new Profile Design and (presumably) the forthcoming 51Speedshop bars you can have aero and decide on your position yourself, rather than have it dictated to you. Which is a big step forward.
I'd note that bars are a component that I've found to be ill served by bike only testing - interaction with the arms a fairly key element. Having a bulky pad harms a bar on it's own, but makes the rider happy. And then we have the debacle of straight and s-bend bars being forced on the world because they were faster in the tunnel (and looked fast), but cause a lot of people to pop their heads up.
I'd like to point out that I was given anonymised results to work with. As far as I could tell Bike 4 was fastest, then Bike 6.
It was only once the analysis was done that Kiley let me know which bikes corresponded to the codes.
Not that I'd be manipulating the results anyway - but we agreed that it was a good way to ensure that there would be no justification for claiming bias in the analysis.
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [fulla] [ In reply to ]
Yup (with an Omega). And don't listen to Rappstar, both the Ventus and Tula are plenty comfy and easy to get along with.
What this test doesn't show is that CdA as a complete unit varies with the bike, regardless of how aero it tests; i.e. your fastest position on bike A is not necessarily your fastest position on bike B.
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [dkennison] [ In reply to ]
There's a lot of talk about your bars, but I haven't actually seen any pictures, apart from the one side-on image that's on the Slowtwitch article. Do you have any images to point us to?
'It never gets easier, you just get crazier.'
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [georged] [ In reply to ]
Some pictures. It's a really nice looking bar. I wish the TriRig Alpha Classic and the Tactical bar would have a baby that I could put on my Felt in a clean undermount configuration. But ultra low stack bars with standard stem clamps seem to be a thing of the past.
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [kileyay] [ In reply to ]
Very clean.
Re: Triathlon Bikes in the Age of Peak Aero: here it is ;-) [Cody Beals] [ In reply to ]
So true. I'm on my third Torhans bottle. Cheap plastic that fails a lot.
Very nice. The worst looking thing are those stupid Di2 levers. I have always hated those things. Kiley should go ETap.
Those pics show the bike way better than anything on their website. It looks awesome. I don't know why they wouldn't take the time to put high res photos & video on their site to show it off. Seeing is believing, and with their sales model... Online image/impression is everything.
What do you want from both bars to make it a complete set-up. I have the classic's and have no issues with any set up I would like to run. OK other than tilt but I worked around that and a 3D print would solve that much better than I did.
One of the coolest things about those pics is that people get to see a bit of what we projected on the floor to help insure the positions were spot on.
pics 6451, 6453-55
Insta
I feel like I should put all my photos out here for the public to see?
