I bought a Lezyne travel pump for... traveling, but pumping is a two person or tricky thing with the provided slip chuck.
I bought a pump head off of E-bay (~$40) that goes onto the hose and I'm pretty happy now... pump is travel sized and the chuck actually holds itself on the Presta valve and works on my disc. Those are two big check marks! I can pump up my rear tire all by myself with two hands working the pump.
Installing the head is pretty easy, remove the fitting on the Lezyne and screw on the KCNC fitting. Video for that here...
https://www.youtube.com/watch?v=y_WwIMQPQBo
One small issue is the metal housing doesn't fit some of the larger "solid" valve stems but I think a slight mod with a drill bit will solve that. Otherwise... awesome for like $100 I've got a travel sized pump that will work with a disc! Will work with other pumps/hoses I'm sure.
Looks like its been modified a little since the review here but it seems like the mod I mentioned is still necessary for larger diameter valve stems.
http://www.tririg.com/...9_Pump_Head_Shootout
Link to the chuck on E-bay...
