captain-dan76 wrote:
Hi,
I just can't get Power Match to work.
When I select "devices", trainerroad shows...
ANT+ Trainer ID 4904
Power Meter 4 ID 4904
Speed/Cadence 2 ID 4904
Tacx Flux 04904
Power Meter ID 59420
Stages ID 59420
I don't know which one should I select, so my Stages PM controls the Tacx Flux.
Maybe someone can help me out?
Kind regards,
Dan
Hey Dan,
First off, let's have you go update the app. We just released an update that eliminates some of the confusion behind so many pairing options you're seeing.
Here's the low-down of what you're seeing:
- The Tacx Flux pairing option is to connect the trainer via Bluetooth.
- The ANT+ Trainer pairing option is to connect the trainer over ANT+ FE-C
- The Stages is the pairing option over Bluetooth.
- The Power Meter with the same ID as the Stages is the pairing option for the stages over ANT+.
- The Speed/Cadence sensor and Power Meter 4 with the same ID as the ANT+ trainer are pairing options that you'll want to forgo pairing. This is because the speed/cadence and power data is already wrapped in the Tacx Flux and ANT+ Trainer pairing options.
So by going forward with the new update, we've decided to hide those other pairing options that won't be needed.
What you'll want to do after updating the app is pair either the Tacx Flux or ANT+ Trainer, then pairing your Stages (either the ANT+ or BT option—but not both). After you have only the two devices paired, access the Stages device settings. There you'll find your PowerMatch settings.
Phew! That was a mouthful. ;)
Give us a shout at support@trainerroad.com if you're still running into any issues after giving the above a try. We'll be happy to help you further.
Get Faster with TrainerRoad
