mjpwooo wrote:
Fella's, can you give me some insights in the differences between the 8' test and the 20' test? SweetSpot Base Mid Volume 1 starts out with the 8 minute test...if we're ultimately going to focus on a 1/2IM distance race, does it make any sense to do the 20' test? Truth be told, I'd rather do the 8' test, as (at least mentally) I view the 8' one as a bit easier than the 20' one. I suck at the 20' test, and have a history of sucky testing....
Thanks!
TrainerRoad did a blog post on this a while back:
http://support.trainerroad.com/hc/en-us/articles/201794984-20-Minute-vs-8-Minute-FTP-Test
In the comment section, Coach Chad offered the following observations:
I recommend using whichever format helps you yield the highest output and therefore gives the best representation of your sustainable power, and these both give you basically the same thing in that respect, an FTP estimate.
If you want a fuller picture of your fitness though, the 20-Minute is arguably the better option in that you can kill that 5-minute effort prior to the 20-minute effort and get a good measure of your power at peak aerobic uptake/VO2 max. Then when you hit the 20-minute jobber, you'll have burned off a bit of your anaerobic contribution and get a fairer representation of your actual sustainable power.
But those details aside, this format will give you a measure of your "aerobic roof" (5-minute) and your FTP/"aerobic ceiling" (20-minute) allowing you to then track not only improvements in both but also how they relate.
For example, riders who can sustain upwards of 85% of their 5-minute power for an hour, i.e. their FTP is 85% (or higher) of their peak aerobic power might choose to target their VO2max while riders under 85% are better off chasing improvements in FTP and the duration they can sustain it with minimal fading.
To further the metaphor, once your aerobic ceiling/FTP is close to your aerobic roof/VO2max power, it's time to raise your roof via VO2max work. But if your ceiling is a ways from your roof, work on raising your ceiling via muscle endurance efforts.
Short answer: Both formats assess FTP but the 20-Minute Test can help you assess pVO2max as well as FTP so it's my preferred format when it comes to developing a greater understanding of your capabilities & limitations.
