The ultimate DIY disc wheel cover how-to thread.
I'm cheap...and I like to tinker. Okay, now that that's out of the way we can get down to business.
In preparation for IMAZ this year, I decided I wanted to run a wheel cover in the rear. I'm on a severely limited budget, and since I wanted to get new tires as well, a WB cover would have been a stretch. I started reading old threads on here about making your own and figured I'd give it a try.
Lucky for me, here in SoCal, a quick search led me to a place in Anaheim called Industrial Plastic Supply. Not only did they have .040 thickness ABS sheets, they can also cut to size. Odd sizes are more expensive, but after measuring my 30mm deep training wheels, I figured out a disc with a diameter of 23" would be perfect. The best part? It was cheap. Like $13 a piece cheap. So I placed an order with Miguel (great guy) and the next day they were ready for pick up.
So lets get started.
Here is a list of things you'll need.
ABS discs
ABS Cement
Sharp cutting tool
Straight edge
Sandpaper
Painters tape
Here's the discs after I picked them up:
Next step is to cut your center hole. This depends of your hub, but I found that 1.5" worked well on both sides of my wheel. I used a hole saw in my drill, but you could use anything really.
This shows you why you have to dish the disc properly to make it fit the dish of the wheel.
At this point you need to cut a straight radius from the center out to the edge. This stuff is really easy to cut. Just use a sharp edge to score it a few times, and it will snap cleanly.
With the radius cut, it will automatically overlap and lay perfectly flat when you put it on the wheel. At this point I suppose you could just tape it as is, but that wouldn't look very great IMO.
At this point I taped the overlap down and used the raised edge as a guide to cut the other side of the pie shaped piece. On the non drive side, this piece is quite a bit larger than the drive side because of the greater dish.
Here it is all taped up and ready to be bonded back together. I put the tape on the outside surface so it would keep the cement from bleeding through.
I used another scrap piece of ABS to make two strips that would be used to make a stronger joint.
This is the cement I used. It's used for ABS plumbing and it's main ingredient in MEK which basically melts the two pieces a bit and then bonds them together permanently.
I scuffed up both surfaces with sandpaper to get a good bond. Then I bent the seam backwards to open it up and smeared a good amount over the gap. Then I popped it back the right way and put a good amount of cement on the back of my support strip, and laid it down. A good way to get a better bond with this stuff is to wiggle the pieces back and forth on each other. Then you just hold it in place for 30 seconds or so, then leave it for 2 hours to dry completely
All glued up and taped till dry:
Here is a shot of the seam. For my first try it looks pretty good I think. I plan on putting some graphics on this when I'm all done, so no biggie.
Drive side taped down. I was thinking of buying some nylon post screws, but I think this looks cleaner and seems to be a rock solid hold. Used 4 small pieces to hold it in place, then used one continuous piece to secure it.
I used some packing tape on the inside to help secure it. Don't think its really needed though.
Cut a hole for the valve. I'll probably get a crack pipe so I dont have to make the hole bigger for my floor pump. (C02 head fits here no problem)
On the bike. There are absolutely no dips or distortion of any kind.
There you go. I just did this today, so I'll report back after some training and I get the graphics on there. Hope that helps somebody.
Re: The ultimate DIY disc wheel cover how-to thread. [undertheradar] [ In reply to ]
Wow. How light is that disc?
Awesome write-up! Too bad I just dropped coin for a Wheelbuilder cover a couple weeks ago. I look forward to DIY'ing my next set though! WOuld you say the .04 is about the right thickness? Looking back would you rather have thicker or thinner material?
Re: The ultimate DIY disc wheel cover how-to thread. [Tyrell] [ In reply to ]
The .040 is the thinnest they had readily available, but it seems perfect. Any thicker and it would be heavier, and any thinner and it would probably be too floppy.
Not sure on the weight since I don't have a small scale, but it seems pretty damn light.
I've been thinking about this all season... You made it look easy so I'll be looking for a local supplier this weekend!
Well done! Im surprised no one has tried to deepen their front wheel yet. It would be trickier but it could be done!.
Edit: nevermind, it wouldnt make sense to make a front wheel deeper because the spokes would be on the outside. Carry on.
who's smarter than you're? i'm!
nice
Want: 58cm Cervelo Soloist. PM me if you have one to sell
Vintage Cervelo: A Resource
Very impressive! I'll be watching for a report on the performance. I already have a Wheelbuilder cover, but I may have to talk some friends into trying this out just so I can take a stab at it ;-)
Nice.
I started doing the exact same thing with some plastic signboard from a local sign shop. I got the NDS done and for some reason lost interest in completing it...but, now you've sort of got me thinking about finishing it up ;-)
Re: The ultimate DIY disc wheel cover how-to thread. [wack70] [ In reply to ]
Wow, I was skeptical...especially since Wheelbuilder's covers are only $90...but you did a great job. How much do you think you spent, all in? (although clearly the satisfaction for you wasn't all financial, as a self-proclaimed tinkerer).
Re: The ultimate DIY disc wheel cover how-to thread. [veganerd] [ In reply to ]
Someone on here did:
http://forum.slowtwitch.com/...l%20fairing;#1858532
´Get the most aero and light bike you can get. With the aero advantage you can be saving minutes and with the weight advantage you can be saving seconds. In a race against the clock both matter.´
BMANX
Sweet! But the real question: does it make the bitchin' whoom, whoom, whoom sound?
Nice job!
I'm faster in Kilometers!
Wattie Ink Triathlon Team
Powered by Accelerate 3
Very tidy job, indeed!
Coaching - Future Endurance
Re: The ultimate DIY disc wheel cover how-to thread. [G$] [ In reply to ]
$30 and about an hour and a half of actual work.
Nice job man, you should start your own business on the side making these!
"Heart Rate, Watts, I have no idea, I race, I don't pace." Andrew Starykowicz
I've done a version with 0.020" styrene sheet (the stuff for sale signs are made of). Not quite as durable, but lighter. For the seam I used matching electrical tape (white in my case).
I'm guessing that if I could use 20 mil styrene, 20 mil ABS would work too.
To the OP, great job! The final product looks really professional.
PS: You can use a modified version of this method to make a deep-V front.
ECMGN Therapy Silicon Valley:
Re: The ultimate DIY disc wheel cover how-to thread. [Titanflexr] [ In reply to ]
I'd be very interested to see that! Got pics or a write up to share?
Yeah...I could see it wouldn't be too difficult. Basically do the same thing, but you make a ring with whatever depth you want. Cut the radius as before to get the right dish. Once you have the two rings all set, you'd have to notch each one where the spokes will come through.
I did it back in the mid-90's, so no pics. Undertheradar has the approach right. You cut the plastic rings and epoxy them to the rim. Then you cut slots that line up with the spokes (much easier with a radially laced wheel than one with crossed spokes), and terminate the slot where the spoke will go through with a round hole (I used a hole punch). You then pinch the two rings together and seal them (you can use epoxy, I used electrical tape). Leave a small area unsealed to stick the valve extender through. You can then seal the slots the spokes went through (again I used electrical tape, but epoxy would give a more finished look).
Since a small flat portion of the rings are glued parallel to the rim the design naturally forms a curved teardrop shape when you join the inside edges.
Great idea I just couldn't justify the amount of time you put into making those vs. buying from wheel builder.
Re: The ultimate DIY disc wheel cover how-to thread. [Ironmanfan] [ In reply to ]
You mean the whole hour and a half? :)
really great work, and thank for the details, something to think about.
what rims are those?
thanks
Great things never come from comfort zones.
Hey man. Great idea and it looks great.
This actually helped me resolve a current issue I was having. I have the notorious Speed Concept / Wheel cover rubbing issue.
You gave me the idea to slice my Wheel Cover just as you did from the center to the outside. When I laid it down, it laid down flatter. There was a small gap in the area I just sliced with a razor blade. I covered the gap up with electrical tap. Used electrical tape to hold the cover to the wheel and voila no more rubbing.
Looks like the opposite issue that you had with your flat piece. The Wheel builder cover appeared to have too much dish. Slicing it allowed it to flatten out. I'm quite happy right now.
So thanks!
