7summits wrote:
Discoverspeed wrote:
Hi Damon
Would you be able to advise if the chain stays of the P5 are apart enough to accommodate the Lightweight Disc which is dished on the non-drive side (dished more than ordinary spoked wheels). The reason I ask is that my LW Disc could not fit one of my rigs as the chain stays curved in too much while on another, the chain stay had an integrated ANT+ antennae structure that is only a few mm clearance away from punching a hole into the disc. I guess this question is generic for other "dished" discs.
Cheers
The Lightweight will fit for sure. I used a Lightweight on my P4 and there was plenty of clearance. If it can fit the P4, it will most certainly fit the P5. What do you mean a "dished" disc? The profile of the Lightweight is extremely thin (at lease the last 2 models).
Hi 7summits - by "dished", I mean the non-drive side of the dish is lenticular in shape - shaped like a lens, straight angled from the hub to the braking edge much like a normal spoked wheel design. The other category of disks are flat sided on both drive and non-drive sides e.g. Zipp.
Because of the lenticular design of the LW Disk (I am using the latest model), the disk cannot fit into some frames with narrower chain stays (e.g., the Storck Aero2 that I am using).
Damon has replied that the clearance should be ok and if the chain stay width is the same as P4, then judging from your experience, the LW Disk should fit. Thanks for your feedback.
