Hi Gerry,
The P5's TRP mechanical rear brake is part number BRL-TRP-925-R-23MM. We have lots of these in stock, and any Cervelo retailer should be able to hook you up with one.
This brake is most similar to TRP's stock "T925.1 Rear" linked here:
http://www.trpbrakes.com/...tid=182&subcat=0 The difference is, our "23" version has the cable noodle swapped left to right to better clear the P5's brake cover. TRP's stock version can work well, especially with standard width rims, but can sometimes touch the cover a bit with wider rims. The cover's not structural, and wind tunnel testing suggests its aero effects are negligible, so you could always leave it off if you like.
Nick's excellent TriRig Omega brake is another mechanical rear brake that works well on the P5.
Are you having difficulty with the Magura hydraulics? I did at first until I got the hang of it. Now they rock!!
Cheers,
Damon Rinard
Engineering Manager,
CSG Road Engineering Department
Cannondale & GT Bicycles
(ex-Cervelo, ex-Trek, ex-Velomax, ex-Kestrel)
