So, the Teflon tape is wrapped around the aero bar extension before it is inserted into the threaded arm-rest piece? I realize that your image below is just a stock example of wrapping threads with Teflon tape, but I don't imagine that tape on the threads prior to tightening down the locking nuts / collars will help anything, so I don't think that this is what you are suggesting.
If I need to wrap around the actual extension, then I guess I need to loosen off the derailleur cables in order to pull the extensions out a bit to wrap them in tape, correct? Right now I can't pull them out very far (only about .5 cm), presumably because there is not enough slack in the cables.
Thanks.
campled wrote:
I used alot of plumbing "teflon" tape.
Now the aero extensions stay in place.
