Re. 2. Wasn't just TR, the Elmnt wouldn't calibrate with it either. The problem there was probably that the Tacx trainer needed to be first calibrated with the Tacx software. Tacx, so my theory goes, hadn't worked hard enough with TR and Elmnt to ensure that their apps provided useful info as part of the calibration fail. Like an error message in TR and the Elment that said "Calibrate device with OEM app first, before attempting to calibrate with us". Or the trainer could have shipped with a tag, attached to the electronic brake, that said "download Tacx Trainer app and calibrate before first ride".
The Tacx arrived with no documentation at all. So there was no clue that it might require some unique calibration routine prior to trying to get TR or an Elment to communicate with it.
I neglected to mention that the trainer didn't want to calibrate with a Garmin 935 watch either.
Re. 3. I didn't mount the electronic brake in the correct position. The device ships with the brake already mounted. Could have had a tag on it that showed different mounting positions for different size wheels, but it didn't have any of that. This is my 4th trainer in as many decades. I've not had to change the mounting positions of any of the resistance mechanisms before, so it was not intuitively obvious that it was necessary this time.
As an engineer, I read documentation. So altho a tag fastened to the electronic brake would have been best, had the issue been addressed in accompanying documentation, I'd have figured it out.
Re. 4. Flimsy electronic brake positioning lever could have been a product of me mounting brake in wrong position. As discussed, I didn't mount it. That aside, I think it's just a matter of a weak design. Had the tensioner stayed together, that plastic lever would have been subject to helacious force in order to push the brake against the tire. The lever was already bending and I didn't have the tensioner tight enough. Sooner or later that lever was going to snap. My old Computrainer was a tank. My TravelTrac, from the early 90's, functions just fine. No plastic on them that bends alarmly in casual use.
Books @ Amazon "If only he had used his genius for niceness, instead of Evil." M. Smart
