Ale Martinez wrote:
This article has an interesting
spreadsheet based on published research relating energy expenditure to stroke and speed:
For example, freestyle at 1.5 m/s (1:07 min/100 m or 1:01 min/100 yd) takes 309 kcal per 1000 m, but only 160 kcal per 1000 m at 1 m/s (1:40/100 m or 1:31/100 yd), according to this work.
This is an interesting article but i wonder if something is a bit off; i say this b/c in measurements of energy used for diff running paces from 5:00/mi up to 12:00/mi, research using same methodology, i.e. metabolic cart measuring amount of O2 burned, has been done many times and has repeatedly shown that the energy cost per mile is the same regardless of speed. Obv, you burn cal/hr at a much higher rate if you're going 6:00 miles vs 12:00 miles, double actually per hour of running, but the rate per unit distance is same. I can't see why it would be diff for swimming, or for cycling either for that matter. Also, the article i linked to up in post 10 has a diff viewpoint, citing a 4 cal/kg body weight/km swum figure, regardless of speed.
Based solely on my personal experience, i think the real truth is somewhere in between, i.e. there is
some impact of speed in any endeavor, be it S, B, or R, but it might be more in the "after-burn" effect, i.e. your body is more revved up, i.e. your HR is still elevated, after a hard effort than after an easy effort of same distance, so you burn more calories over the next 10-15 hrs than you would normally. So many variables...:)
"Anyone can be who they want to be IF they have the HUNGER and the DRIVE."
