Superman position
In case you all wondered: CdA (m^2) of 0.145, an almost 100 W reduction. :D
Re: Superman position [Schubi] [ In reply to ]
Can you hold it for 112 ... ?
WD :-)
Re: Superman position [WD Pro] [ In reply to ]
2 min was uncomfortable enough... :)
Any data on:
-Shoes
-Top tube mounted bottle
-Oversized RD pulleys
ECMGN Therapy Silicon Valley:
Re: Superman position [Titanflexr] [ In reply to ]
Shoes: No improvement over specialized trivent for me: might be dependent on pedaling style as someone I have tested at the tunnel actually did save Watts. But I checked twice, no gain for me. I raced with the trivents, as the toebox is so narrow in those s-works that I can only stand them for 90 min of riding.
Top tube bottle: I cannot reach bottles behind me, but wanted another bottle. Small aeropenalty for me that I gladly take. Unfortunately the setup started to come loose during the race.
Oversized pulleys: No idea. Did not test with regular pulleys.
Titanflexr wrote:
Any data on:
-Shoes
Thanks!
BTW for that position do you recommend a two beat or six beat kick?
Your crank arms are to short
Re: Superman position [7401southwick] [ In reply to ]
Your feet are too high...
You need to set the cranks at 90/270 for best results. Save another 1 watt.
In all seriousness, could you actually get into that position while riding?
TrainingBible Coaching
http://www.trainingbible.com
Re: Superman position [motoguy128] [ In reply to ]
Yes easily done on a road bike. But I will leave it to someone else to try that on a TT bike in the aerobars.
Re: Superman position [nickag] [ In reply to ]
I will try to do better next time! :)
+1 You're giving up more watts.
Every season during a slow point in the early season races, some pro will do it to get a little camera time for sponsors and break up the monotony.
Serious question: which bottle cage do you have along your top tube? I've contemplated a similar setup.
Re: Superman position [GreenPlease] [ In reply to ]
How do you take a pee?
i think they are called Lezyne side flow, you get them as left or right sided. On amazon.
I have them on my MTB :
You can get them in left and right hand versions :-)
WD :-)
LOL
for anyone that wats hints on how to do it....
https://www.youtube.com/watch?v=bvmibwafGXc
Re: Superman position [JRC] [ In reply to ]
I assume that's a Cobb saddle.
Yeah, but at what yaw? Also pedals parallel to the ground will increase the watt savings over 121 miles significantly.
Should be called the ''Vincent Black Lightning'' position;
https://en.wikipedia.org/wiki/Rollie_Free
''Sweeney - you can both crush your AG *and* cruise in dead last!! 😂 '' Murphy's Law
Re: Superman position [Sweeney] [ In reply to ]
That is just insane... Nice bike though.
Re: Superman position [Slunnie] [ In reply to ]
Fizik :)
It was the ''worlds fastest motorcycle'' well into the modern era. The Vincent Black Lightning even has a song written about it;
https://www.youtube.com/watch?v=AxKTzwaEa2o
Saddle is too high.
