NUFCrichard wrote:
I heard Jim Vance talking about running power meters on IM talk. He said that the fastest runners don't have the highest power outputs or the highest W/kg values, rather they are the most efficient. He also said that sometimes when people blow up at the end of a race, they start putting out more power, not less!
That was the point when I decided against getting a running power meter. In cycling W/kg is pretty closely related to speed, if it isn't in running, then I don't really think that a running power meter is a worth while piece of equipment to use.
In any one individual at a given point in time just running naturally, speed and power are highly correlated (i.e., R values >0.95). The same is true for VO2 and power. (Indeed, it is because of this close coupling that I previously held that simply knowing your speed was enough.) There can, however, be significant differences between individuals, as well as within the same individual at different points in time. This is not different from cycling, in which the power required to achieve a given speed varies significantly between and even within individuals.
Where cycling and running do differ is how you interpret the data. In cycling, more power is generally better, and so it is relatively easy to use power as the metric to adjust your effort, judge the efficacy of your training, etc. This is not always the case, however - for example, many years ago I did some experiments to determine the fastest way around a particular short loop on my road bike, and learned that I was faster by remaining seated (and hence more aero) up the one climb, vs. standing to generate more power that was simply wasted against additional wind resistance. Similarly, some people find that they are faster in TTs and tris by adopting a very aerodynamic position, even if it compromises their power output.
Analogously, it is possible to run faster by generating more power, but it is also possible to generate more power by not go any faster - the only real difference is the relative frequency with which such circumstances are likely to occur.
