Re: Strength training pros and cons [FrançoisM] [ In reply to ]
Nope..the OP wrote:
"For example, I consider physio (strengthens inured joint structure), big gear on the bike (could help with power on the flats) and hilly trail runs (helps with stabilizers, and running strength) to be a form of "strength" training.
Thoughts?
Maurice "
Anyway I'l play..
So about your crap dinner. At what point does strength training become useless to you? You accept big gear work is strength training and useful? What about 15 minutes of lunges in the garage with a barbell slung over the shoulder - springing back on your toes? Still strength work? Still useful?
Or does the fact you're not actually doing the run or bike mean by definition this training is useless?
What about 15 minutes of stride outs while the potato is baking....
Re: Strength training pros and cons [mauricemaher] [ In reply to ]
Thanks, a few more questions if you don't mind.
mauricemaher wrote:
Peak tested VO2 power (power at the end of a 20 min Vo2 max test) was only moderately changed for both (350-370 for me, 280-300 for her) so top end did not change as much as low end. VE (lung volume) was unchanged, O2 (vs Co2) patterns were changed for the better.
What equipment and protocol did you use to test this?
Quote:
The training program on the bike was only about 2-3 hours/week (with some longer IM tempo intervals) as we were doing our longer stuff outside on the skate skis, the whole program had pretty minimal intensity at this point.
So in addition to the weights, you were doing 2-3 hours of IM effort riding? What effort were you doing on the skate skis?
Quote:
The thing I take away from these is that the weight I lifted at program start was purely anaerobic, where as at program end I was lifting that same weight (180 lbs) at the 1 min mark. So a change for the better, in terms of systems used at a given load.
So 180 on the leg press was a max effort at the beginning?
Shane
Re: Strength training pros and cons [Salmon Steve] [ In reply to ]
What about them? Are you suggesting they help performance?
http://www.fmcoaching.com / http://elpasotricoaching.wordpress.com
You know I am.
I'm asking your opinion.
I don't think it's useful.
Performance wise I don't think there is much, if any, evidence that it helps.
But I'm 45 and not built for endurance sports so I am not ever going to make money at this. While tri is the only sport I compete at I enjoy lifting and like being able to pick up pretty much anything. So I'll take the performance hit to look good on the beach.
The biggest pro is that your wife is watching me as I finish 5 minutes behind you while your scrawny butt is off getting a drink.
I'm beginning to think that we are much more fucked than I thought.
Shame on you.
From a performance standpoint, aside from a couple of recent papers suggesting it could improve efficiency (running and cycling) I think it's not needed really. That said for well being, if an athlete still wanted to lift to not be the scrawny kid around the block then that's a different story :)
Re: Strength training pros and cons [Big] [ In reply to ]
Big wrote:
In that case let me chime in...N+1...............Strength trained before getting in triathlons = No injuries, Stopped strength training for about 3 years and did a LOT of swim biking and running (14 to 16 hour weeks) = every overuse injury in the book, Started strength training again = no injuries and feel more durable than ever and still training around 8 to 10 hours (no IM's)...........Overall - very little change in performance either way.....I would say I am faster now because I have been at it longer so performance isn't really static with respect to being an indicator of whether or not it increased MY performance...
but I do feel 10x better....
The 8-10 hours of training, is that all s/b/r? Or does that include the strength training? And what are your exercises/intensity for the strength training?
It's hard to equate the no injuries = strength training when the times are so markedly different. It may be possible that you did not pursue recovery enough when you were doing near double the s/b/r that you are doing now.
John
Top notch coaching: Francois and Accelerate3 | Follow on Twitter: LifetimeAthlete |
so you swam, ran and biked more and you got more overuse injuries? wow, that's a stunner.
To the OP:
pros: it's good for your health and you will look better naked
cons: it will result in you doing less s/b/r and therefore you won't be as fast as you would if you spent that time s/b/r'ing.
Just decide which is more important to you. Personally, I lift some, but I didn't for the approximately 10 years when I spent a lot of time on SBR.
Re: Strength training pros and cons [mr. mike] [ In reply to ]
That's not really a fair statement. If he spends 3-4 hours a week lifting, then he's putting in the same amount of time training. Which is why I asked about it, I would suspect that the total time spent training is only different by an hour or two, but the recovery is different.
I think when he ramped up his s/b/r, he didn't allow sufficient recovery time. But, like most things, that's just a theory at this point.
John
Cons: the only con I can think of is if you are doing hours a week and taking away from your key activities.
Pros: The use of activity specific strength training, IMO, can be a huge boon and help prevent injury in the long term. And that means you can train more often, instead of sitting on the coach or water jogging. This would include adding plyometrics to your track sessions etc...
Ian
We'll have to agree to disagree on this one.
With all things, regardless of papers, it comes back to 'it depends'.
Does gravity work? Well, it depends. ;-)
You stick to your papers mate...
Looks like my papers help me do a pretty good job with the athletes I coach. Anyway, it's the crossfit season for you soon.
Yup I'm sure they do, reading your site seems you have some solid age groupers congrats.
The stuff I posted above was all part of the plan for winning the world cup overall in 08.
So again, it depends on the athlete. Let's agree to disagree - I really don't like dick swinging contests.
Re: Strength training pros and cons [gsmacleod] [ In reply to ]
velotron, Korr met cart with O2 and Co2. Vo2 max tests started at 60-100 watts and going up by X watts per minute until failure at 16-20 min. Did not test BL as I use more of a "staged" test for that where you sit at an effort for 3 min in order for BL values to saturate.
Skate skis replaced long bikes, Total low-ball effort. for the long rides av HR is around 130-140, for skate skiing I would allow this to drift up by about 5 beats. IM stuff was done on Saturdays where the ride would be about 2-3 hours with about 40-100 min at just above IM tempo (about 5 beats or so) while monitoring power vs hr, we did mostly 20 min intervals.
yes 180 lbs to start (fail on 20-25 reps then pull a 45, ie 180, 135, 90, 45)
Keeping in mind that in most of the earlier phases of strength training, the focus was balance, economy, efficiency and injury prevention. for most of us we can do this at home with about 100$ worth of bands, altus disc, swiss ball, a bit of core, exercise of your choice etc. At home it is also pretty easy to throw in 15 min here or there, I see nothing wrong with this approach as long as people like it and it works for them.
I wouldn't say that this particular phase in the gym is something every one "should" do, this is a variation on a variation of one way to go about reps and sets that may work for the right person at the right time.
In fact my whole strength program is a variation on a variation, taking some stuff from the former track coach here Derek Evely and some stuff from a pretty good Ag cyclist who used to live here Olav Stana, throw in a bit of my own stuff, mix with some trial and error and you have a program which works pretty well for some people but is and always should be evolving for the better.
For some people they never get to this point because we want to spend as much time as possible getting people strong enough so that they don't get injured when intensity picks up.
This is something an athlete "could" try to see if it fits their program. At the end of the day you would know after 2-3 weeks and a few tests with your power meter if it was right or should be dropped in favour of other training.
I am also curious to see if others have done "cut-downs" and how it has worked for them.
There was no Rugby World Cup in 08! Busted mate!
Salmon Steve wrote:
Thoughts?
Maurice "
Anyway I'l play..
None of the things you list are true strength work.
True strength work is useless when it interferes with sport-specific training, either through opportunity cost (you could have been doing something else) or failure to adequately recover and this reducing the effectiveness of subsequent sport-specific training. It is also useless if e training adaptations are counter-productive: the famous mitochondrial density and capillarization stuff.
And to the OP who thinks that 20-25 reps is anaerobic: wrong. It has a major aerobic component, so the fact that you increased the weight over your gaining period includes improving your aerobic capacity, which likely contributed to your improved power on the bike.
"Go yell at an M&M"
Re: Strength training pros and cons [Devlin] [ In reply to ]
but he's not spending 3 or 4 more hours training the same way. I think if you spend 12 hours per week sbr vs. 8 hrs per week sbr, your risk of an over use injury goes up no matter what you do with the "extra" 4 hours when you reduce sbr hours. If you spend the extra 4 hours lifting, you might hurt something else, but it's not going to cause, for example, plantar fasciitis or IT band syndrome or the other things that we have regular threads on.
Salmon Steve wrote:
It depends....
To the person that says if you have time to do a strength session you'd be better off going for a swim, bike, or run. What about if you don't have time for those - what if you have time to quickly get in a strength session using your own body weight in front of the TV whilst cooking dinner? But don't have time to pack a bag and head out to the pool?
Are you actually getting quality work done?
To that scenario I'd say forgo the chin-ups and take care of your life. Use that time to get the kitchen cleaned up, dishes done, and bills paid. If you are that crammed for time you are probably better off resting and giving yourself some down time.
Touche!
http://www.sweat7.com
Facebook Page: Sweat7
Twitter: @sweat7coaching
Glad you are out of the doping threads and discussing things like Mauna Kea and weights.
I was just doing body weight squats and calf raises for 30 minutes reading and re reading this thread....OK, not 30 minutes, just 2 minutes...
carry on.
I do find some of the best anaerobic training are 50m all out sprint and plymotrics.
After over a year of not being able to do them, I've just started that back last month.
Add in some deadlifts and ab work, and I feel like a normal human again.
Too much aerobic work sends my body out of balance....ancient hunters needed a balance of aerobic and anaerobic just to survive. As we age if we don't work the anaerobic system, will it gradually goes away (use it or lose it) and then the ancient hunter becomes excess baggage in society because he can't hunt anymore without an anaerobic system....think about that for a second guys....
Dev
Re: Strength training pros and cons [devashish_paul] [ In reply to ]
Well, as soon as I get chase by a saber tooth, I'll think about sprints.
