apache wrote:
HI Travis,
I have a functional leg length discrepancy with my right leg. I've inadvertently stumbled on some issues through ski boot fitting/alignment processes that has sparked some "a-ha, eureka" thought with respect to cycling fit issues. The boot fitter I use is pretty well known in skiing circles and through their processes they have found that about 80% of their customers have more valgus in the right leg than the left leg (if I remember correctly, something about tibial twist).
This is getting a little deep (disclaimer: I'm not a clinician or biomechanist by any means, but always studying, observing, and learning). I have read something to this effect before, in which there are trends in natural asymmetries, although I don't think these can always be attributed to a specific, single cause, but instead are more indicative of a series of things happening. It's a bit of a "chicken and egg" conundrum, and there is a subtle difference in stating "the right leg is functionally shorter than the left" versus "the left leg is functionally longer than the right." The pelvis is very rarely symmetrical. With all that said, I haven't really tracked these trends in the studio. I should - it would be fascinating, if anything.
What did your ski boot fitter do to accommodate your LLD?
apache wrote:
I wonder if this same valgus causes this left psoas issue that many people have?
Maybe - it's all a delicate balance. If you really want to dive deep, check out the book "Anatomy Trains" to get an interesting view of how everything is interconnected and held in balance.
apache wrote:
If I develop saddle sores, it's almost exclusively on the right side (mostly where the leg meets the groin).
I am thinking about a shim in the 3-5mm range.
Thoughts?
G
Because we're all asymmetrical, we often adapt and can deal with our natural asymmetries, within reason. The right side saddle sores are the actionable item here, and I think you're developing a valid hypothesis, but I am going to be cautious with my suggestions without actually seeing you on the bike in person. I would say a 3mm shim is worth a try, but I would also want to see how your knees travel, what your foot structure looks like, how your foot behaves under load, etc. The functional leg length difference could be at the foot (i.e., greater arch collapse under load on the right), within the joint alignment, or muscular imbalances.
Travis Rassat
Vector Cycle Works Noblesville, IN
BikeFit Instructor | FMS | F.I.S.T. | IBFI
Toughman Triathlon Series Ambassador
