In Reply To:
In Reply To:
In Reply To:
.250 - .255 m^2
.249.
Candy@sses ... ;^>
I think I'm barred from entering this contest Gee that second frame looks familiar...
That
is you Eric. Thanks for digging the frameset out of your garage and selling it to me!
The answer is 0.0228 m^2.
We only have two entries in my little contest and RChung's "Price is Right"-style guess is closest. So I guess he has "smart guy" bragging rights over Tom A for the time being! Though he gets some style-points deducted.
OK, now that I have the data in front of me:
Photo #1. I have data for three 10-mile TTs on three separate nights from July-August 2007 for which I did a Chung method CdA analysis. Equipment the same as I described earlier and as shown in the photo, except for the 3rd TT where I had a water bottle cage mounted on the downtube (no bottle). CdA calculated at 0.2716, 0.2733, and 0.2735 . Wind speeds and direction, temperatures, and air density varied greatly on the three nights (I corrected for air density as well as the temperature effect on Crr), so I'm pretty happy that the results varied as little as they did.
Photo #2. I have data so far this this year for three 10-mile TTs from March to April on the same course as 2007. Equipment the same as I described earlier and as shown in the photo, except for the 3rd one where I had to use a 23 tire because I broke my 20. Wind speeds and direction, temperatures, and air density varied greatly on the three nights. CdA calculated at 0.2497, 0.2504, and 0.2499.
Average of the CdAs in the 1st set: 0.2728 m^2
Average of the CdAs in the 2nd set: 0.2500 m^2
Difference: 0.0228 m^2
That's the difference I found between an "aero" frameset and frameset that is actually aero. And based on the tube widths and aspect ratios, the "aero" Fuji Aloha 1.0/Motobecane Nemesis is more aero than a number of other "aero" framesets
What does this mean in terms of results? You know, that actually-going-faster part? Well, there just happen to be two TTs I did with almost identical air density and power output. Makes for an easy comparison:
TT#2 from the 1st set: June 20, 2007. Calculated air density = 1.167 kg/m^3; averaged 329 watts; time: 22:33
TT#3 from the 2nd set: May 7, 2008. Calculated air density = 1.168 kg/m^3; averaged 328 watts; time: 22:02
31 seconds over 10 miles = 1.93 seconds/km = 0.42 seconds/km per 0.005 m^2 change in CdA. Hey, somebody ought to write a rule of thumb ;)
Rik
